Old 09-30-2013, 03:05 PM
Deereman39's Avatar
Deereman39 Deereman39 is offline
Vehicle: 1996 Ram 2500 Laramie SLT
Trim Level: Laramie SLT
Deereman39 is on a distinguished road
Default 5.9 Engine
Can someone explain the difference between a Stroker kit and just Boring the cyclinders say .30 and planning .30 off the heads?
Thanks Ed
Old 09-30-2013, 08:53 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Boring .030" will yield only about 3-4 cubic inches in increased displacement. Milling the heads reduces combustion chamber volume and increases compression by a point or more depending on other engine factors. Milling too much is just plain bad as you can't really get it back once it's gone and you can easily wind up with an engine that won't even run on premium gas. You may also need to make adjustments to pushrod length. Stroking is a more effective way to increase displacement. Adding nearly 1/2" stroke to a 5.9 yields just over 40 cubic inches in increased displacement.
Old 10-25-2013, 12:28 AM
spun360 spun360 is offline
Vehicle: 96 ram 1500 367ho
spun360 is on a distinguished road
a .030 bore over will yield 365 cid.
a stoker kit for a .030 bore will yield a 408 cid engine.
no replacement for displacement!
