Old 09-29-2013, 12:16 AM
DatacomGuy DatacomGuy is offline
Vehicle: 2013 Dodge Ram
Color: Mineral Gray
DatacomGuy is on a distinguished road
Question Anyone add remote start to their 2013 yet?
Not PnP like previous 4th gens.. Anyone hardwire one in yet?
2013 1500 CC | Mineral Gray | Hemi 5.7 | 3.55 LSD | 15% | Dip'd Badges | 4" AirBox CAI | Cut Antenna
Old 09-29-2013, 02:58 AM
Planert360 Planert360 is offline
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
Planert360 will become famous soon enough
Interested in this too, with winter coming up I might have to be the guinea pig here. I HATE a cold truck when I go to work, or on my way home.
Leave it to dodge to play with the wiring and make then come up with a new method of doing this, eh?
Old 09-29-2013, 08:04 PM
marvin02's Avatar
marvin02 marvin02 is offline
Trim Level: Tradesman QC 4x2
Rep:30
marvin02 is on a distinguished road
If you want to do the install you can get the factory remote start, which is "plug-n-play", with programming at your local dealer. If you follow the link above you can download the install manual. There are some threads with more details.
Old 09-29-2013, 10:07 PM
ChrisG's Avatar
ChrisG ChrisG is offline
Color: Maximum Steel Metallic
ChrisG is on a distinguished road
I'm looking to do this too, but the issue I'm running into in my little bit of research so far is that I have the Keyless Enter 'n Go system already, and the add on remote start seems to indicate that it's not for trucks equipped with that. I know there's got to be a way to have both since I've seen listings for trucks with both, but I may have to break down and have the dealer do it unless someone has some insight on that combo.
Old 09-29-2013, 11:48 PM
Color: Mineral Gray
My understanding is that 2013 is not PnP.. Must be programmed and hard wired..
Are you saying that's not the case?
Old 09-29-2013, 11:59 PM
Vehicle: 2013 Ram
Color: Cherry Red
Rep:54
The unit he's describing is the factory add on option. The kit that isn't plug and play is an aftermarket kit that uses the key fob.
Factory one cost allot nor but it's plug and play and if buyinga new key fob it would have a start buttonvs the aftermarket kit you hit lock 3 times.
Old 09-30-2013, 09:58 AM
NCBEAST NCBEAST is offline
Rep:16
NCBEAST is on a distinguished road
So $249 + getting the dealer to program the fobs....Does anyone know hoe much the dealer charges to program the fobs?
Old 09-30-2013, 11:42 AM
Sethw3 Sethw3 is offline
Vehicle: 2013 Dodge Ram CC Laramie
Color: White/Grey
Sethw3 is on a distinguished road
If its the factory one. It should come with new key fobs that have the remote start button on it. Mine did. and I have the stock ones
Old 09-30-2013, 02:51 PM
Rep:16
Agrred but doesn't the new fobs have to be programmed by the dealer to match the vehicle?
Old 09-30-2013, 05:00 PM
Color: White/Grey
Im sure they do. But the dealer installed mine... I would have never guessed that the damn thing is on the back wall of the cab.....
