Old 09-26-2013, 06:31 AM
southbronxems southbronxems is offline
Vehicle: 1994 Dodge Ram 1500
Color: Dark Blue
southbronxems is on a distinguished road
Default 1500-2500 swap.
Hi all, I dont post here often but I creep a lot. I was wondering if anyone knows if its possible to swap out a 1500 suspension for a 2500 suspension. My 94 1500 has a 3" body lift with a 5" skyjacker suspension lift. I was thinking about taking off the skyjacker and installing a 2500 suspension instead. My lift has been on for about 10 years, and Im thinking of making it a bit less wild. Any thoughts or experience with a similar issue?
Thanks, Andy...
Old 09-26-2013, 10:39 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Sounds like an expensive proposition. When my Ram was new, I had the dealer install an extra rear leaf and, because the 05's have torsion bars I could raise the front. Dealer put on excellent Rancho 9000 shocks. Almost 200,000 miles later, she's done more work and towed more than most 3500's and still gets decent milage. Unless you tow a heavy trailer or haul very heavy loads, do you need the extra weight and poorer gas milage? BTW, check out a 2006 hemi Mega Cab 1500, not sure how many years they made em, but check one out, either 2500 or 3500 chassis! Friend of mine has one.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 09-26-2013, 11:04 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Thanks, Andy...
Yes, this is a common swap. There are some particular differences 98 and newer, iirc. This is in the realm of control arm bolts and speed sensor that I recall. The top thing to work out though is for the rear leaf springs. half ton leafs are 2.5" wide while heavy duty trucks are 3". So your option there can be:
1. Cut perches off the rear axle, which would be a D60 or D70, and put new ones on for 2.5" leaf springs that you currently have.
2. Replace spring hangers on your half ton with those from 3/4 or 1 ton truck for the 3" springs and bolt up the axle.
New wheels would be needed, 8 lugs. If the axle you find are in pretty decent shape, then you may not have to dig into them to replace things. This can potentially be alot, however, your area and searching can get decent prices hub-to-hub, maybe $200-$500 axle. Most ppl do this swap for the added strength, aftermarket support, and ability to use them in offroad abuse. Goes back to how/why you want to use them. Who cares about the cost.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
