Old 09-25-2013, 08:28 AM
ninja99 ninja99 is offline
Vehicle: 2012 ram
Trim Level: big horn
Color: mineral grey
Rep:26
ninja99 is on a distinguished road
Default drove with e brake on
what a dumb ass I am. I picked up my boat last night from getting winterized. got out and set e brake, talked to my mechanic and hooked on, got back in truck and forgot to disengage e brake and drove off. it is a 22 ft fibreglass boat so thought it was just the weight of the boat. thank god it was only 2 concessions. got almost home and saw the red exclamation mark flashing on dash but didn't realize that was the problem till I drove into laneway and smelled the rear brakes burning. not red hot but slightly steaming. cooled them off by letting it sit outside for an hour. now the question is did I do any damage to cable or just took some life off the brakes? I can't believe I did this. 3 quarters of the drive was at about 40 miles an hour and the rest was at 50 miles an hour.
Old 09-25-2013, 09:22 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I doubt that you're the first person to do this, and I doubt that you'll be the last.
I would think that there wouldn't be any damage to the cabling. You probably reduced the life of the rear brakes significantly though. Be sure to keep an eye on them, and also you might want to get the rear rotors checked, with that much heat generated you might have warped them pretty severely.
good luck
Exco
Bill
Old 09-25-2013, 09:39 AM
AZRAMRT's Avatar
AZRAMRT AZRAMRT is offline
Vehicle: 2012 ram
Trim Level: R/T
AZRAMRT is on a distinguished road
I would say replace the pads and rotors anyways with that much heat is very bad for rotors and pads at least the oem stuff. And no better excuse for an upgrade right?
Mods: airaid cai,flowmaster muffler,6000k low 5000k fogs,LEDs, painted badges,Boston acoustic sub
Old 09-25-2013, 10:21 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Agree with Both above posts. You prob did not damage the cable, but I would pull the rotors off and replace them with the pads (not worth having breaking issues for the price of 2 rotors, pads and some time), do a full inspection of the calipers if all is good grease them up and you should be fine.
Old 09-25-2013, 07:41 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3238
PaulMys has disabled reputation
Ouch! Yeah, like the others have said- I'd replace the rotors & pads. I don't think these RAM brakes are meant to glow red like the Nascar guys'. Good luck ninja.
Old 09-25-2013, 08:16 PM
12sport 12sport is offline
Vehicle: 2014 Ram 1500
Rep:59
12sport will become famous soon enough
As hot as your rear brake assemblies (probably) got, I'd consider flushing/changing fluid while you're at it.
Old 09-25-2013, 08:30 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
The rear brakes are a Drum-in-Disc setup. Your regular brakes are disc, then inside the rotor (hub) is a small set of shoes and a drum-type setup for the parking brake.
Doubt you warped anything, you probably got it warm, just dont do it again, and change the brake shoes inside the drum if you are that worried about it.
Diesel Technician-PACCAR Inc.
Old 09-25-2013, 08:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ this.
The ebrake and regular brake are two different systems. The ebrake is the only thing that will be effected, your regular brakes are fine.
Sean
Old 09-25-2013, 08:57 PM
Rep:2620
e brake pads will be Glazed from the heat
i would replace them, if it were mine
not as cheap as using heavy grit sand paper on them, but ..........
Old 09-25-2013, 09:24 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is online now
The Sound of Eight Hooves
Rep:532
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Good advice guys! This is one reason I set my brake every time I park, even on flat surfaces when it isn't necessary: habituation.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
