Old 09-23-2013, 06:34 PM
YELLOWCAT01 YELLOWCAT01 is offline
Vehicle: 2013 RAM1500 4X4
YELLOWCAT01 is on a distinguished road
Default New 2013 ram 1500 4x4
I just purchased a 2013 ram1500 4x4 and im looking at lifting it alot and putting 35's on stock 20's.. Can i get that with a 3" ft and 2"rr leveling kit... There sspacers for the front and rear shocks... Any input will help
Old 09-24-2013, 02:03 AM
The Hemster's Avatar
The Hemster The Hemster is offline
Vehicle: 2013 Dodge Ram Express
Color: Mineral Gray Metallic
Rep:69
The Hemster will become famous soon enough
We'll I have the 4" Mopar lift and I have 20s and 35s. It sit I'll rubs at full lock
Old 09-25-2013, 02:21 PM
macabra11's Avatar
macabra11 macabra11 is offline
Trim Level: Big Horn w/8 spd
Rep:23
macabra11 is on a distinguished road
That surprises me. Are your new tires wider? Did you have to add any backspacing?
Old 09-25-2013, 04:48 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The highest you want to lift the front is about 2.5". The best way to do it is with adjustable Bilstein 5100 front struts. Set them at 2.8" (they settle down to about 2.6") and call it a day. Then if you want to add some more height to the rear look into Top Gun Customz rear coil spacers. You will have to change out the shocks as well if you do a 2" coil spacer.
Are you looking to fit full 35x12.5 tires on the stock rims or just 295/60/20's? And what type of tire are you looking for? An AT or MT? That will make a difference.... Either way you're going to need at least 1/4" spacers to clear a tire that wide. If you're looking at Toyo MT's or Nitto Trail Grapplers they measure wider when mounted (about 13.4") and might not fit on the stock wheels with only 1/4" spacers.
Old 09-25-2013, 08:58 PM
Rep:69
It was done at the dealership. Tried to go on the wheel maker website but it didn't list the back spacing.
