Old 09-23-2013, 04:19 AM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Call the Shaman... or priest!
Old 09-23-2013, 09:20 AM
mace of bass mace of bass is offline
mace of bass is on a distinguished road
Anytime a vehicle goes into reverse (either driver or otherwise) while cruising in drive, it is forced to shut down. In other words, it WILL NOT go into reverse.
Is that what is happening? You hear a clunk then the truck shuts down? If the truck doesn't shut down, it is not likely going in reverse. Of course, it is your truck and you know it far FAR better than I, but vehicles these days just will not go into reverse when you are going 40 mph down the highway.
Old 09-23-2013, 09:39 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Although you stated the dealership did oil changes and service work to this used Laramie, I highly doubt that it was a problem free truck. The unfortunate ugliness about used car lots is "Sold As Is". Good luck with your truck as I hope you find a remedy to this road demon.
Old 09-24-2013, 08:49 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Your transmission will not go into Reverse all by itself (while driving down the road). You have to physically move the shift lever into the Reverse position in order to engage Reverse; the computer cannot shift it into Reverse by itself.
I suspect that you may have a Trans Range Sensor (TRS) problem, or more likely a wiring problem (in one of the TRS circuits). Did you have a P0706 (Trans Range Sensor Rationality) fault?
Does your truck have a PRND display where all the letters are always visible, but one is highlighted in a different color? For example, in Park the P is green and the others are all white. The N and D also show up in green when they are selected. In Reverse, the R is red (and all the others are white). Here is what I bet happened: If the PCM detects an invalid TRS signal, it sets the P0706 fault, and lights up ALL the PRND positions at once. In older trucks, you would get a "box" around all the positions. But in yours, since it merely changes color to indicate the current gear position, when it highlights "all" of the positions, P, N, and D turn green, while R turns red. So it LOOKS like it is displaying Reverse, when in reality it is highlighting all of the positions.
So I'm guessing you just have a bad wire (or flaky connection) on one of your TRS circuits.
Old 09-24-2013, 10:19 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Great info! Thanks for sharing.
Old 09-24-2013, 09:21 PM
muddy53 muddy53 is offline
Vehicle: 2011 Dodge Ram 5.7L Hemi
Rep:34
muddy53 is on a distinguished road
Default Dealer
Hope the dealer makes good on this fix. Should still be under warranty so they should take care of it.
I would suspect that going into reverse at 40 would damage the trans, u joints, transfere case and differential. May be time to get rid of it?
Good luck!
Old 09-25-2013, 02:10 PM
Maine-Ram's Avatar
Maine-Ram Maine-Ram is offline
Vehicle: 2011 Ram 1500 / 2002 Ram 1500
Trim Level: SLT Big Horn
Color: Gold
Rep:30
Maine-Ram is on a distinguished road
Trust me, when you get rid of this lemon, and own a normal, functional, not bipolar Ram, you will love the truck! My first truck was a Ram, and never looked back! My former boss is a ram guy. His nickname in the woods is "Dodgeboy".
He has own'ed dodge since the as early as he can remember. Even used to own old dodge semi trucks he used to haul wood with. Currently has 3 of those trucks in a pit, waiting to be restored.40+ years of logging experience and using only 1 brand of truck to get to the job is insurance enough for me that these trucks are tough like nothing else.
Second thought. I'd imagine the shifting from shifter to transmission is electrical. Could the issue not be that the "solenoid" (for lack of a better term) which reads what position the gear lever is in, is faulty? Perhaps it is malfunctioning on occasion and "reads" the truck has been placed into reverse.
Also is the shifter on the column or on the floor? Happen when you hit a bump?
Old 09-25-2013, 02:33 PM
picker picker is offline
Vehicle: 2005 ram
Trim Level: st
Color: mineral grey
Rep:9
picker is an unknown quantity at this point
Dealer can pull up your vin and print history of your truck, Ask-em.
Old 09-25-2013, 02:59 PM
Vehicle: N/A
Rep:358
Originally Posted by Maine-Ram View Post
... Second thought. I'd imagine the shifting from shifter to transmission is electrical. Could the issue not be that the "solenoid" (for lack of a better term) which reads what position the gear lever is in, is faulty? Perhaps it is malfunctioning on occasion and "reads" the truck has been placed into reverse.
The 8-speed trans is "all electronic" (there is no physical shift linkage), but the 6-speed still uses a conventional shift cable that moves a lever on the side of the transmission. To get into Reverse, you MUST physically move that shift lever to the Reverse detent. It doesn't matter what you do with the solenoids, you can't get Reverse unless the manual valve (which is physically connected to the shift lever) is in the Reverse detent.
I'm guessing that the issue is with the Trans Range Sensor (TRS), which (as you suggested) is what "reads what position the gear lever is in." If that sensor gives a faulty (invalid) signal, you get the P0706 with "all PRNDL highlighted." I doubt it would actually give a true "Reverse" display, since for that to happen, three out of the five TRS wires would have to switch to the wrong state. I can see one wire going bad, but typically you don't have three of 'em fail simultaneously.
Old 09-25-2013, 07:46 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2011 Ram Express
Rep:92
Graygoose will become famous soon enough
Originally Posted by bhepper View Post
A 2011 w/17k miles is suspicious? What would you think of my 14k miles then?
Mine is a 2011 and only has 11,400 miles to date....low miles can happen, but sometimes you have a short distance driver like mine, not a highway driver.
2011 White Ram Express, Custom American Racing 2-piece forged, Nitto 420s 22's,Extang Trifecta, Belltech 2/4 drop, Magnaflow catback,KICKER sound system,CodeAlarm remote start, '13 Retroshop Headlights and Tail lights, Bedrug, Custom MGP Caliper covers, LED reverse lights, AAC interior LED and licence plate LEDs, BT Catch Can,Weathertech mats
