Old 09-20-2013, 11:06 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Default How do you get the frill inserts out?
I've searched and I cant find anything. How do you pull out the inserts in the grill? It looks like they're almost melted into the other plastic. I'd like to paint those green but I'm only going to do so when they're out of the grill. I know you can buy different inserts, so they have to come out somehowww.
2001, Second Gen. Sport if that changes anything.
and I, uh.. meant "grill inserts"... :lol:
Air horn "AHHOOOGA" horn,
Green Interior LEDs
Old 09-21-2013, 04:49 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Dynamite! Guaranteed to get the inserts out.
Old 09-21-2013, 06:50 PM
Rep:529
haha i'll rephrase to question
"How do i get the grill inserts out WITHOUT HARMING THEM enough to put them back in?"
Green Interior LEDs
Old 09-21-2013, 07:54 PM
Rep:2616
This video may help a bit, they took out the whole grill
the guy used WD-40 to break the screws loose
He should have used PB BLASTER instead, squirt it on & walk away for 5 or 10 minutes
almost all of the videos that i watched, they cut the center part out a certain way
or they use clip on inserts
there must be a better way, like drilling out plastic rivets, or something
Old 09-21-2013, 08:31 PM
MorePwr's Avatar
MorePwr MorePwr is offline
Vehicle: 2011 Ram Crew Sport
Color: Deep Water Blue Pearl Coat
Rep:50
MorePwr will become famous soon enough
I do believe they are plastic welded together. It will require grinding away some of the plastic and then reattach with adhesive of some sort.
Sean
McGaughy's|Spohn
Old 09-21-2013, 09:46 PM
Rep:529
so basically, I have to break them off, then glue back on? haha
Green Interior LEDs
Old 09-21-2013, 09:51 PM
Rep:2616
take off the grille & lay it on some cardboard
then use Painters tape or Frog tape to cover what you don't want painted
scratch up the rest or use some kind of binding agent & start painting
Old 09-21-2013, 10:09 PM
Rep:529
that would always work. But I didn't know if there was some sort of secret that I was missing..
Green Interior LEDs
Old 09-22-2013, 01:24 AM
God Bless Texas!
Rep:2929
Less dynamite. HaHa
On mine, it's held to the frame with a friction type clip. You know, the PITA type that you have to bend up to get off, but once you get them off you usually can't use them again because they're so bent up.
Old 09-22-2013, 01:33 AM
Rep:529
Like MorePwr said, I'm pretty sure they're like plastic welded on. I accidentally popped and broke a few off when i was tinkering with them.
Green Interior LEDs
2nd, grill, honeycomb, inserts, mesh
