Old 09-20-2013, 10:13 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
how much does that usually run? do they have a website?
Green Interior LEDs
Old 09-20-2013, 10:33 PM
I push the skinny pedal
Rep:3277
You may have to buy a set and get the dimensions of the halo then see if they have a set in the diameter you want. This is how I've done my last 2 sets. They don't have a headlight assembly for the 2nd gen, but they can work with you on the ring size. They're a vendor on here, but it's faster to email them than get a reply via PM.
http://www.automotivelightstore.com/...e-halokit.aspx
Kurtis
Old 09-20-2013, 10:36 PM
Rep:529
thanks! ill give them a shout when im ready for my next project.
Green Interior LEDs
Old 09-20-2013, 10:46 PM
Rep:529
how would you put LED rings in these? DO you think the HALOS would just pop off?
http://www.ebay.com/itm/99-01-DODGE-...1c4862&vxp=mtr
Green Interior LEDs
Old 09-20-2013, 10:53 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
if you want to do some quick green, throw some green strips in the grill!
Old 09-20-2013, 11:02 PM
Rep:529
give me two minutes and i'm actually about to start a threat about the inserts :lol:
Green Interior LEDs
Old 09-20-2013, 11:03 PM
Rep:529
^^that was supposed to be all caps.. and idk why the :lol" didnt work..
Green Interior LEDs
Old 09-21-2013, 12:11 AM
Rep:3277
Like most "LED" lights those are just a couple of LED bulbs that shine onto a textured bar/ring, and they're not great. I much prefer to use SMD led rings/strips or see if they have plasma rings in the color you want.
Those halos would just pop out. They'll be in a recessed ring, so you'd just need to measure the inside and outside diameter to get the size you need. For my old fogs I could only get a ring set that was 1mm larger than what I needed, so I just trimmed the bezel down and nobody was the wiser.
The 3 LEDs in the top I would leave, but I'd look at getting a 4" pair of SMD strips and replacing that ugly bar at the top. If you wanted to get really adventurous, you could run a LED turn bulb and tap the SMD strip into the turn signal system to really make it stand out.
Kurtis
Old 09-21-2013, 12:19 AM
Rep:529
yeah that bar is gross... But i just spent about $100 on Green LEDS. So new headlights and more LEDs will have to wait. hahaha Thank you very much though. This will be what ill do when i get new headlights. which is pretty high on the to-do list.
Green Interior LEDs
Old 09-21-2013, 01:42 AM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
CdnoilRAM is probably the master of anything green and cool as he continues to build up his.
Tow mirrors up for the haters
green, hid, install
