Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 09-19-2013, 01:07 PM
vinoaddict vinoaddict is offline
Vehicle: 2010 Mercedes m
vinoaddict is on a distinguished road
Default 2014 Power Wagon: 4.10 axle gears versus 4.56 gears
I am considering the 2014 Power Wagon. I really liked the 2013 model, but I have heard that the 2014 Power Wagon will change from the 4.56 to the 4.10 axle gears. I have seen some negative comments regarding this change.
Can someone explain in simple terms what effect the change from the 4.56 to the 4.10 axle gears will have on the Power Wagon? Why was this change made?
Thanks
Old 09-19-2013, 06:03 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Simply, 4.10 will give you better mileage and a more normal truck like experience. 4.56 will give you greater torque (i.e. that 10k trailer wont feel like its 10k) at the expense of fuel mileage.
In all honesty, if you plan on leaving it bone stock and enjoying the capabilities it was built with 4.10 might be a great choice. If your like the rest of us and like to mod and build then the 4.56 is the way to go. I am already considering 5.13 with my next set of upgrades (might be a hint!!).
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 09-19-2013, 06:29 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
I agree with battlerattle. With the 4.10's, if you don't change your tire diameter from OE/stock, then mileage could be what the 2014 PW is trying to improve a bit on. But with a 4.56, being able to move up to some 37" tires just look badass and still wont hurt the fuel mileage too bad.
Old 09-19-2013, 07:02 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
But wont the 14s have the 8 spd option?? The lowest gear is lower than the 6spd so it almost make up for it?? Just what i remember on the whole 8spd 3.21 vs 6spd 3.55 thread.
New audio build in progress
Old 09-20-2013, 01:12 AM
Lil Black 4x4 Hemi's Avatar
Lil Black 4x4 Hemi Lil Black 4x4 Hemi is offline
Vehicle: 2008 Reg. Cab/Bed 4x4
Rep:70
Lil Black 4x4 Hemi will become famous soon enough
Send a message via AIM to Lil Black 4x4 Hemi Send a message via Yahoo to Lil Black 4x4 Hemi
Everything I've found saying they are going to 4.10s appears to be from July or earlier. I'm looking heavily at getting a '14 and the dealer is telling me he's been told they are sticking with 4.56s. Not that dealers know a WHOLE lot, but just saying there's a lot of confusion and you can't build a '14 online yet AND the dealer told me the first run wouldn't be until March they had said.
Luke
K&N Cold Air Intake, Magnaflow Exhaust, Rancho RS5000s, TRUXXX Leveling Kit, Heavy Duty Towing Shackles, Recon Smoked Cab Lights, Chrome Fender Flares, Stainless Door-sills, Chrome Door Trim, Atturo Trail Blade 35x12.50R20, METAL Grille Inserts.
Old 09-28-2013, 12:46 AM
Trail Whale's Avatar
Trail Whale Trail Whale is offline
Vehicle: 2012 Ram 2500
Trim Level: Power Wagon ST
Color: Mineral Gray
Rep:87
Trail Whale will become famous soon enough
I'd love to have the 2014's 11.5" rear axle in my 2012! (but with my leaves, not the coils) With the 2013 and earlier 10.5" rear, the lowest gearset you can go with is 4.56 versus with the 11.5" you can go with 5.13 gears! If ever go with larger than 37" tires, I will find an 11.5" out of a leafsprung (2013 and earlier Diesel) truck and swap 5.13 gears and a 2014+ Power Wagon's locker into it! (that way I get to retain my stock locker wiring and I get the stock combo of a limited slip when unlocked and locker!!!)
With the added power (especially it coming on stronger at low rpms) of the 6.4L, I really don't think the 4.10s will be much if any of a penalty (I actually think it will be better!) compared to a 5.7L with 4.56 gears. If they keep the 4.56s, so much the better!!!
Old 09-30-2013, 09:40 AM
Rep:256
Whoever told you the lowest the 10.5 can go with is 4.56 was smoking crack. Sure you have to shop around, but the 10.5 can do 5.13 all day.
Old 10-01-2013, 12:54 PM
Thanks for all the input.
Interestingly, I noticed that the 2014 models for the 2500 HDs are available on the Ram website, but that the Power Wagons are not yet listed. Unless I am doing something wrong, at this point it is not posible to "build" a 2014 Power Wagon on the Ram website. Perhaps Ram has not yet finalized the specs?
Old 10-03-2013, 09:22 PM
Color: Mineral Gray
Rep:87
I've not come across any lower than 4.56, if you've found some, if you don't mind, please post a link to somewhere that carries lower.
I'm not surprised, I bet they probably won't have it up for a while yet. It's probably just due to the Power Wagon being a lower sales volume model so it's a lower priority.
Old 10-03-2013, 09:30 PM
Rep:256
Google AAM 10.5 5.13 gears. Remember the axle is AAM not Chrysler. Most are listed as GM gears, but a good shop will know which are compatible. Sierra Gear for example makes a comparable ring and pinion.
