Old 09-17-2013, 08:25 PM
JaxLoki's Avatar
JaxLoki JaxLoki is offline
Vehicle: 2013 Dodge Ram
Trim Level: Sport Crew 4X4
Color: Deep Cherry Pearl
Rep:14
JaxLoki is on a distinguished road
Default BDS vs. Rancho 4" Lift
I've been looking for sometime now and debating which lift kit to go with. Of course each distributor relates that their kit is better. I just want to know if any of ya'll have either or have had experience with either brands. I've had Jeeps in the past so all I have had experience with is Teraflex and the like.
Going with 4" versus 6" because I have only 6.5" from the top of the damn shark fin to the garage opening. Wish there was a replacement for the shark fin that would give me 2" back......
Additionally, who makes ProComp tires? Maxxis or Cooper?
Mufflex DOD14M, BakFlip Fibermax, K&N Drop-in Filter, Stubby Antenna, In-Cabin Air Filter Mod, Painted Tips, Debadged and B-pillar tape removed, Plastidipped All Chrome, Recon 60" Xtreme Light bar, Linex'd Go Rhino Dominator III Steps, 295/70 18 Trail Grapplers, Fuel Throttle 20x9, ReadyLift SST
Old 09-18-2013, 01:41 AM
Either kits are pretty good.
I'd lean more towards the BDS as its tried, tested and true and you get lifetime warranty.
As for height and clearing the garage...what tire size did you want to run?
A 4" kit and 35's will push you 5" higher than where you are at now.
6" and 35's will get you 6.25" higher over stock
6" and 37's will get you 7.25" higher over stock
Based on this, I'd say either option 1 or 2 and option 1 being a safer choice
Anyway I can assist, let me know
fastNugly@bullysperformance.com
Old 09-18-2013, 12:28 PM
WhoDAT WhoDAT is offline
Vehicle: 2012 Ram Sport
Trim Level: sport
WhoDAT is on a distinguished road
I have a 4" BDS and like it a lot. Cooper makes the Pro Comp tires
Old 09-18-2013, 12:34 PM
Trim Level: sport
Also the 4" BDS raised my front5.5" and rear 2" (1\2" rake) with 325x65x18 Cooper STT 2012 Ram Sport
Old 09-18-2013, 04:47 PM
Im sure you meant that when you installed the 4" lift and 325 tires which are 35's, you went up 5.5"
The 4" BDS kit on its own will not net you that lift.
It will only net you 4"
Old 09-18-2013, 11:02 PM
Trim Level: sport
Yes tires plus 4" kit
Old 09-19-2013, 12:39 AM
Sweet
