Old 09-17-2013, 02:10 PM
Bix Bix is offline
Vehicle: 2012 Dodge Ram 4x4
Bix is on a distinguished road
Default Another LED Resistor Question
What I got:
2012 Ram with HID projectors and a DRL conversion lighting up amber turn signals full time.
What I need:
I'd like to convert frond and rear turn signals/brake to LED but do not want a hot resistor on the full time front signal lamp.
Can I get away with a resistor on the rear bulb only (both sides) and if so, what value will do this?
I'm assuming a rear only resistor will only warm up while the signal flasher is in use.
All ideas appreciated.
Cheers,
bix
Old 11-10-2013, 09:26 AM
McArthur McArthur is offline
Vehicle: 2002 Dodge Ram 2500 Diesel
McArthur is on a distinguished road
Default Same problem
I replaced my Bed with a Utility Bed W/ LED lights. The flashers blinked fast so when I had tiime I put a 10ohm resister ( 25 watt) thinking that they would only get warm when I had the blinker on. Blinkers worked perfect but when I stopped the truck it was hott.
I cant help yet but hopefully a experenced member may know where the answer is
Thanks for any help
Old 11-10-2013, 10:35 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You need a resistor for each LED turn signal light. So if you put LED lights front and rear you will need 4 resistors.
Here is a good reference: http://www.ddmtuning.com/Products/LED-Resistor
Here is a wiring diagram: http://www.autolumination.com/images...stallation.jpg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
