Old 09-17-2013, 11:44 AM
ckage83 ckage83 is offline
ckage83 is on a distinguished road
Default BDS 6" w/ Bilsteins - quick fact check
I just wanted someone with a similar setup to check my plans and make sure I'm on the right track before I pull the trigger.
2011 Ram 1500 4X4 LH: 6" BDS Suspension lift with Dual front stabilizers and Fox 3" rear shock. I plan on installing my adjustable bilsteins up front. My installer says I dont need to jack up the Bilsteins since the BDS kit comes with front blocks.
Do I skip the blocks and use the adjustability on the Bilsteins or go the way the installer reccomends? And should I go with the reccomended 3" rear shock or go to the 5"? I have a top-gun customz leveling kit on it now that pushes it 2 3/4" up in the front and 3/4 in the rear but the shocks are starting to sag and I cant get an accurate OE height estimate.
Old 09-17-2013, 08:15 PM
Nobody has anything?
Old 09-17-2013, 08:30 PM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2009 Ram Crew Cab
Rep:27
casper97ta is on a distinguished road
If your truck is a 1500 then you dont have steering stabilizers, only solid axle 2500/3500's can add dual steering stabilizers. As for the front lift, you have to use the strut spacers provided in the BDS kit in order to achieve the lift in the front end. You can install the Bilsteins and use them to add additional lift in the front to level the truck out. Im not 100% certain if the BDS kit claims to level the truck with the lift kit or if additional leveling is needed in the front.
I would leave your rear spacer in when you install the lift as well. As for the setting on the Bilsteins, 2.1 is usually a good setting for leveling the truck after a 6" lift kit especially with the 3/4" rear spacer.
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 tune - K&N - DeeZee Tailgate Assist - A.R.E LSX Color matched hard tonneau - Debadged - Cabin Filter - 2 12" Sundowns in Foxbox
Old 09-17-2013, 08:32 PM
Thanks for the input. I now my truck doesn't have front stabilizers stock but the BDS kit comes with an option for dual front stabilizers. From what I've read, its well worth the money/insurance against wobble or an unsettled feeling.
Old 09-17-2013, 10:06 PM
Johnz's Avatar
Johnz Johnz is offline
Vehicle: 2012 Dodge Ram
Color: Cherry
Johnz is on a distinguished road
someone as an alternative to adjustable bilsteins? im running them now maxed out but wouldnt mine running just a shock. any taughts on this?
Old 09-17-2013, 10:07 PM
Johnz's Avatar
Color: Cherry
I bought it and it dindt work for shit, do some research on the dual steering stabilizer. My buddy at dodge laughed at me when I told im I bought that.
Old 09-17-2013, 10:09 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
run the bilsteins for sure... those bds lifts have a nasty rake on them.... also i would grab the 5'' rear coils and get rid of your coil spacers... better ride And you have the option to go higher later if you want too
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 09-18-2013, 12:14 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1945
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Some good info from capser and chadster above.
First off, ditch the steering stabilizer. It won't make any difference on your IFS truck. As casper said, they are for 2500/3500's with solid front axles. It's literally a waste of money on your truck.
Go with the 5" rear coils for sure. If you're going to buy a lift kit you might as well go as big as you can. You'll need to run the front lift spacers that come with the BDS kit and then set the Bilsteins up a bit to get rid of the rake. If you're just using the 5" coils (no coil spacer) then you'll most likely want to set the Bilsteins at 1.4". If you do use the spacers you'll want the Bilsteins at 2.1".
Sponsored by:
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | S&B Intake w/ Scoop
Old 09-18-2013, 12:34 AM
Vehicle: 2012 Dodge Ram CC 4X4
Color: PX8 Black
Rep:1769
If you run the 3" rear, your truck will be level right from the get go
Maybe requiring Bilateins at 0.7 to fully level it.
5" rear and you'll practically have to max those Bilsteins to be close to level
But this is all dependent on your current rake
As for the strut spacer, that stays on.
The Pre load is what has to be removed and that's only 5/8"
Did you ever find that email you spoke of?
Either way, let me know
As for going big? Determine your tire size you want to run.
There is no point going so huge if you're only going to run 35's
If you decide of 37's you'll need to factor in your gearing.
3.55 + 37's = shoot yourself, as its a dog
I know. I ran that way for 1 week before I dropped it off to get gears done....lol
for the best pricing in the business, email me @ fastNugly@bullysperformance.com
2014 Ram Hemi Tuning now available from Diablo Sport get yours today!
Old 09-18-2013, 02:14 AM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:179
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
I have the BDS 6" lift on mine with the 5" rear coil and the Fox shocks. As Brandon said, don't get the steering stabilizers, they're not needed on the 1500's IFS. Bilsteins are set at 1.4 and the truck is level
