Old 09-17-2013, 05:22 AM
cak0130 cak0130 is offline
Vehicle: 2009 Dodge Ram 1500
Color: Blue
cak0130 is on a distinguished road
Default Need help with tire sizing
Hello everyone,
So I'm looking to get some different rims and tires for my 09 Ram 1500. Right now I just have the stock rims and tires. I want to drop down from the stock 20" rim to an 18x9. I have a 2" level in the front, and I'm wondering how big of a tire I can get without them rubbing? I would be up for getting spacers too if needed. Any advice would be helpful!
Thanks!
Old 09-17-2013, 09:34 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
if you get a 0 offest wheel at minimum. You'll definitely be able to clear a 35x12.5x18 tire.
if you want a good stance (tires sticking out some) then start going negative. -12mm stance with 35s would look great on your leveled truck!
Old 09-17-2013, 01:15 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
With only a 2" leveling kit (rather than a 2.5") running 35's is pushing it. You will probably end up rubbing on the back of the inner fender near full lock. Especially if you go with a -12 offset wheel. However it is fairly easy to fix that with either a heat gun or drilling a couple holes and zip tying the fender back a ways.
I'd probably stick closer to something that measures 34" tall if I was you.... you'll just have less problems to deal with.
Old 09-17-2013, 01:25 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Personally, I'd go with a 33 inch tire so the wheelwells don't look so "stuffed".
Old 09-17-2013, 03:26 PM
Color: Blue
Thanks for the input guys! I'm considering going towards a little bigger size even if it looks a little tight in the fenders bc eventually I'd like to get a 3-4" lift.
