United Radio
Old 09-19-2013, 12:28 PM
sean2d sean2d is offline
sean2d is on a distinguished road
Originally Posted by Farmer1 View Post
Found all the old hardware from the original kit . Installed the Ford / spacer bracket hooked it all up . Drops quickly for the 1st 1/3 or so of travel and then slows up nicely . Just enough clearance for everything .
You're experiencing the same thing I did, when I used the Ford drop plate with the Dodge shock. If you remove the shock from the Dodge kit, and use the shock from the Ford kit, instead, the tailgate will lower slowly throughout its range of travel.
Old 09-19-2013, 10:19 PM
Mzerr927 Mzerr927 is offline
Vehicle: 2013 Ram 1500 Big Horn
Rep:34
Mzerr927 is on a distinguished road
Man, this is disappointing. I hope the come up with a accurate fix for the '13 ram. One kit, one installation
Old 09-20-2013, 11:28 AM
katokahn99's Avatar
katokahn99 katokahn99 is offline
Vehicle: 2013 2500 CTD Laramie Mega 4x4
Color: Black Gold Pearlcoat
Rep:14
katokahn99 is on a distinguished road
The fix is already out...use the entire 43200 kit.
Old 09-20-2013, 01:37 PM
katokahn99 is on the right path. But, if you just buy the 43200 kit, you won't have the right torx wrench for the Dodge bolts. I don't have the two kits with me, so I can't say what the wrench sizes are, but the 43200 and 43300 kits don't include the same size torx wrench. If you have your own torx wrenches, you can jump right to the Ford kit. Otherwise, you may want to see if the Dodge kit works, first, and then let DeeZee send you the Ford kit, for free, if you find the Dodge kit doesn't work right. Just remember not to slam the tailgate shut immediately after you install the Dodge kit, as you may find it scrubs the paint on your tailgate...close the tailgate slowly, keeping an eye on the area around where the cable attaches to the tailgate, because that's the area that will get scratched, if there is a problem. If there's a clearance issue, lower the tailgate, remove the shock, and contact DeeZee for the Ford kit.
Old 09-22-2013, 10:39 PM
Jabalone's Avatar
Jabalone Jabalone is offline
Vehicle: 2013
Color: silver
Rep:30
Jabalone is on a distinguished road
The ford kit #43200 didn't work for my 2013. It rubbed and damaged the tailgate cable (even being careful). Had to go back to the Ram kit which scraped the paint (raising it once carefully, but apparently not carefully enough!). Then I used my own thinner spacer on the ram kit as others mentioned to finally make it work (painted body color). Sean2d's is right about the different torx wrench sizes for ford and ram kits too. Not sure what's taking Deezee so long to rectify the unit for the newer model Rams. It must be costing them shipping different models, parts, torx wrenches etc.. to Ram customers trying to get their product to work right. When it does work right though, it is sweet.
Old 09-27-2013, 05:47 PM
mdavis501 mdavis501 is offline
Vehicle: 2013 Dodge Longhorn
Trim Level: Longhorn
Color: Western Brown
mdavis501 is on a distinguished road
So, is the model number for the ford working perfectly? I'd really like to add this, but I don't want the paint rubbing off of the tailgate.....then it wouldn't be worth it. Can you confirm the model number?
Old 09-28-2013, 12:13 PM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Hi all, I did the install a couple of months back when I first got the truck .. this is what I bought and it worked perfectly. No issues what so ever.
DZ43300 DODGE RAM 1500 PICKUP (2006 - 2013) SLT
Regards
Old 09-28-2013, 10:23 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Installed the kit on my 13 ram , followed instructions to the letter . Tailgate seems to bind when closing . Sent them an email ---no response . Called the 800 number told the young lady my trouble and she said some 13's were having a problem .I asked if the kit number 43300 was the correct model it was . They now had an updated kit that would solve my problem it is kit number ( I lost the paper with the update but I am sure she said it was 43200 ). Well kit 43200 came ups today . Here in about 3 days . My big question is the new parts are in a package with # 43200 and it says its for a ford f150 2004 - 2011 .
Is this correct ?? any one elsse have the binding problem . tried doing a search here to no avail . Any help is appreciated.
DeeZee still showing correct Ram 1500 part number as: Part #DZ43300 RAM TRUCK RAM 1500 PICKUP (2011 - 2014) as of Sept. 28, 2013
Old 09-29-2013, 08:28 AM
Clarkgriswald's Avatar
Clarkgriswald Clarkgriswald is offline
Vehicle: 2013 Dodge Ram Sport
Clarkgriswald is on a distinguished road
Same here. Works like a Swiss watch no rub. Got it from Bully's.
Old 09-29-2013, 02:26 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:68
Cookie Monster will become famous soon enough
I'm ordering mine from Bully's too. good to hear its working well on the 2013's
