United Radio
View Poll Results: which cai would you go with?
Volant with air scoop 2 15.38%
Spectre 3 23.08%
Airaid 2 15.38%
waste of money 6 46.15%
Voters: 13. You may not vote on this poll
Old 09-21-2013, 08:16 PM
Bigred74's Avatar
Bigred74 Bigred74 is offline
Vehicle: 1999 Dodge Ram 1500
Rep:254
Bigred74 is a jewel in the roughBigred74 is a jewel in the roughBigred74 is a jewel in the rough
Originally Posted by crazzywolfie View Post
have you fixed your plenum gasket? could have spent the money toward fixing that if you haven't. could have also order a better throttle body. there is a guy on ebay that sell them pretty cheap compared to other companies. he also makes aluminum plenum pans.
http://www.ebay.com/itm/251342488680
is that hard to fix? ive thought about a throttle body too.. maybe next pay check. does the plenum gasket need to be replaced on all 2nd gen dodges or how do you tell if its bad?
*Bedliner paint job, leveling kit, 3'' body lift, 17'' eagle alloy rims series 197, 315/70/17 Nitto Trail Grappler M/T tires, S&B cold air intake, 52mm ported and bored throttle body, Superchips 3865 programmer
Old 09-21-2013, 08:50 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
it can be sometimes if you run into issues. to fix the plenum gasket you have to take the intake off because plenum gasket is on the bottom of the intake. the plenum gasket on all magnum engines usually need to be replaced after long enough time. they eventually start to leak. there are a couple theories why they start leaking there is one sure way to fix it.
here is a picture of the stock plenum pan with a blown gasket on it. you can ignore rust. intake came off a truck at the junkyard that had no throttle body.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
Old 09-22-2013, 03:14 PM
Bigred74's Avatar
Rep:254
ah ok is there a brand or place to buy that you suggest? is there any other mods worth lookin into when you have that torn apart?
Old 09-22-2013, 04:34 PM
hughes engines is the only place that i know of that sells a complete kit.
http://www.hughesengines.com/Index/p...p?partid=27091
you can also just buy the aluminum pan on ebay and buy all your own gaskets. i know some people don't like the gaskets that come with the hughes engines kit.
http://www.ebay.com/itm/DODGE-JEEP-A...622732&vxp=mtr
some people also recommend replacing the water pump, timing chain with a double roller timing chain and installing a tensioner. i don't know the best place to buy them but mopar part numbers are
P5007709 Timing chain tensioner
P5249267 Double roller chain and sprocket set
Old 09-22-2013, 06:21 PM
Bigred74's Avatar
Rep:254
hmmm... looks like my next paycheck is goin towards some of this! thanks for the info man!
Old 09-22-2013, 07:50 PM
your welcome. i know if i can ever manage to save up some money i will most likely be doing the same work to my 93. already got the aluminum pan. just got to order everything else.
Old 09-22-2013, 09:35 PM
Bigred74's Avatar
Rep:254
What else are you wanting to order? is the FI AIRGAP KIT worth 600 bucks? what all would you replace on a daily driver but also wanting to have good amounts of power for off roading every once and a while?
Im prolly never gonna sell this truck so thinkin even tho its my daily driver once i get a better job and make more money get a newer truck or car but keep this as a toy
Old 09-22-2013, 09:44 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
That Hughes Plenum kit is great. It's very complete.
Old 09-23-2013, 02:17 AM
i think 1.7 harland sharp roller rockers and bosche 4 hole injectors would be about the only other upgrade i would do to my engine. i have heard harland sharp roller rocker arms is the best bang for your buck as far as upgrades go.
http://www.summitracing.com/parts/cs...iew/make/dodge
not sure if the FI AIRGAP KIT is worth $600. i think with other upgrades it might help a bit but not as much as you think you get for $600
Old 09-23-2013, 08:47 PM
Bigred74's Avatar
Rep:254
Post
ook thanks what do you suggest for the ignition coil and spark plugs and wires? the full tune up from hughes be a good choice to do?
cai, spectre, tuners, volant
