Old 09-16-2013, 09:03 PM
Tippmannr Tippmannr is offline
Vehicle: 2010 Ram 1500
Tippmannr is on a distinguished road
Default Tow/Haul Mode
Hey everyone. So on my 2010 1500 Hemi Sport whenever i hook something up to the truck, hit the tow/haul button, and shift into drive it always goes into manual mode. Any way around this?
Thanks
Old 09-16-2013, 10:18 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
No that's part of the benefit of tow/haul mode. When you go to tow/haul mode it probably displays "5" or maybe "6" on the newer models which is the highest gear. It will shift through all gears so you don't have to worry about it.
Tow/haul mode locks out the highest gear(2nd overdrive), extends shift points and engine braking, and uses 2nd prime(the 3rd gear) in upshifts.
If you're not familiar with the weird 2nd prime gear of the transmission, then basically to sum it up it works like this:
In normal driving the transmission shifts 1,2,4,5,6. In T/H mode it shifts 1,2,3,4,5. 2nd prime(as it used to be called) is now called 3rd gear on the newer models.
Sean
Old 09-17-2013, 05:38 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
^^^This^^^. Tow/Haul is your friend.
333Half the beast
I used to be
Old 09-17-2013, 08:57 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 Sport
Color: Flame red
Rep:2554
Excellent points made here.
Yes, tow haul is a good thing.
Best, Bruce
Sure you can take my truck, the keys are under my Akita.
