Old 09-15-2013, 04:52 PM
2012whitesport 2012whitesport is offline
Vehicle: 2013 dodge ram 1500 sport
Trim Level: Sport fully loaded
2012whitesport is on a distinguished road
Default HID headlights
Hey guys so has anyone out there installed 9006 HID's on their low beam instead of 9012? Well they fit! I ordered low beams and fogs for my 2013 and they ended up sending me two sets of 9006's. well I was annoyed and just wanted to install them and not have to wait to return then get a new set and they fit perfectly and run fine!
Old 09-15-2013, 04:55 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
That's what I run in my lows! You have to trim one tab on the bulb a bit but that's all!
Big Red my old 2011 Sport
Old 09-15-2013, 05:35 PM
I didn't even have to trim anything. Just thought I'd post it cause I seen in the past on a thread someone said only a 9012 would fit cause it has the 90 on the end of it
Old 09-15-2013, 05:46 PM
Talon66 Talon66 is offline
Rep:92
Talon66 will become famous soon enough
9006 fit easily with no modification.
I installed 55w HIDs in my headlights and 35w HIDs in my foglights, both 5000k
2013 Ram 1500 CC Black
Factory: Hemi, 8spd, 4 Corner Air suspension, Rambox
Mods: DIY FX-R Projectors w/4300k & 50w, Custom Dual Relay Harnesses, Tinted, Debadged, blacked out emblems, Stainless Works LT Headers, AVS Low Pro Visors, Magnaflow #12569, Kicker Soundgate, Diablo DCX - HF Tuned
Old 09-20-2013, 01:12 PM
MurderedOne87's Avatar
MurderedOne87 MurderedOne87 is offline
Vehicle: 2013 Ram 1500 Black Edition
Trim Level: Tradesman/Express
Color: All Black
Rep:70
MurderedOne87 will become famous soon enough
Did you have to have error code eliminators or relay harness to keep them from flickering? I am looking to add the 9006 into my black oem projector headlights and was wondering.
I have both just need to know if they are even necessary?
DO you have any pics of the After? Day or night?
Old 09-20-2013, 02:31 PM
cferia cferia is offline
Vehicle: 2013 Ram
Trim Level: 1500
cferia is on a distinguished road
Whats up, I am curious do you have the projector headlight? I want to add HID's to my 2013 1500 Sport and wondering if the 2006 will fit? Current factor bulb I have seen is hir2? Will the 9006's fit as a replacement?
Much Thanks!
Old 09-20-2013, 02:43 PM
Stump3r's Avatar
Rep:1266
Much Thanks!
Yes the 9006 will fit.
Old 09-21-2013, 08:31 PM
I didn't need error code eliminator or relay. Works perfect no flicker. Ya I have the projectors and I ordered HIR2 but got the 9006 but they ended up fitting anyway
I tried adding pics to the first post but didn't work. Ill post pics here soon
Old 10-25-2013, 01:31 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Where did you get the kit from and how are they working now?
