Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Power Wagon
Old 09-14-2013, 10:04 PM
Marc308 Marc308 is offline
Vehicle: 2013 Ram 2500 4x4
Trim Level: Tradesman
Color: Maximum Steel
Marc308 is on a distinguished road
Default Power Wagon suspension vs standard 2500 suspension questions
Hi guys, I just bought a 2013 2500 4x4 crew cab short bed Tradesman a few months ago and I was thinking about lifting it to look like a Power Wagon.
I am wondering how much taller the Power Wagon is compared to my regular 4x4. I know about the lower gearing, lockers, sway bar disconnects, and winch being the obvious differences, and I don't plan on altering those things on my truck. I just like how the Power Wagons look.
The questions I have are:
Does the Power Wagon use longer coil springs or spacers in the front? I don't really care about spring rate, I am fine with the ride my truck has.
Control arms, and track bar the same size as the standard 4x4?
Is the rear suspension the same height as a standard 4x4?
I would be glad to provide measurements from my truck for comparison.
Thanks.
Old 09-14-2013, 11:05 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Would this comparison not seem like Apples & Oranges? I've been trying to find these Power Wagons at auctions (the knot heads won't sell'em). Must be a reason. R...
Old 09-15-2013, 12:19 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
The PW sits 2" higher than the factory 2500 4x4 (Hemi). They use taller springs in front (no spacers) and a micro-leaf pack in the rear (similar to a block). The spring rates for the PW are slightly different than that of the standard 2500 4x4 (Hemi) to be a bit firmer. Combine that with the slightly larger tires and a PW overall is just about 2.5" taller than your standard 2500 4x4.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 09-15-2013, 10:19 AM
Thanks battlerattle.
Old 10-26-2013, 12:49 AM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
I may have many left over Power Wagon suspension components soon - Rancho 4 inch lift is on the way :-) If you are interested I could probably be talked into selling them ?
