Old 09-14-2013, 10:03 AM
Emmett01 Emmett01 is offline
Vehicle: 2013 ram 1500
Trim Level: Outdoorsman
Color: Dark blue
Emmett01 is on a distinguished road
Default 13' ram 1500 4 inch lift?
So I just got my 13' ram 1500 outdoorsman and was wondering first if its possible to lift my truck because of that air ride garbage and second will it void any if my warranty's if I do so? I was looking for a 4" lift and if it doesn't void my warranty suggestions of good lifts would be appreciated. Also what would be my max tire size if I were to lift it 4"?
Thanks for your help
Sorry if there tons more posts about this I'm new the the forums
Old 09-14-2013, 02:29 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
If you have the air ride then no, there's not currently anything out there to give you more height. I believe companies are working on it but nothing has been released yet.
Essentially you can't do anything to your suspension because of the air ride... You're pretty much stuck with what you've got for now unless you want to pull out all the air ride and put standard suspension on it.
