Old 09-12-2013, 11:18 PM
Ramboner's Avatar
Ramboner Ramboner is offline
Vehicle: 2013 Ram Sport
Ramboner is on a distinguished road
Default Levelling kit or Billsteins?
I'm in a 13 ram sport, just bought a great set of wheels and tires off a neighbour that had them on his 12 ram. 285/65/20 BFG AT on black XD Monsters. With less than 4000 km! I tried one on the driver side front and it had about 1/2" before rubbing at the back fender well and top control arm. Looking for best ride options and best fit from either a levelling kit or maybe Billsteins. I don't really off road, so what's my best options? Appreciate your feedback. Thanks!
Old 09-13-2013, 01:24 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Go with the Bilsteins to level for sure! You won't be disappointed, they are by far the best way to level a Ram and will give you a better ride quality than stock.
Send the guys at Bully's Performance an email at sales@bullysperformance.com. Be sure to mention that you're a forum member and they send you a quote with discounted pricing.
Old 09-13-2013, 03:03 AM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:187
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
What Brandon said. I got mine through Bully's as well. And the ride is better than stock
Old 09-13-2013, 11:01 AM
Amell Amell is offline
Vehicle: 12 ram 1500 laramie
Amell is on a distinguished road
Is it possible to do do blistens and a levings kit?
Old 09-13-2013, 12:09 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
if you leave the bilsteins at 0" setting. do not use the bilsteins to level and add a spacer kit on top
Old 09-13-2013, 12:50 PM
Rep:2026
Yes, what gonefishin said ^^. You can't use a leveling spacer and then Bilsteins for extra lift without doing a differential and control arm drop (essentially a 4" lift kit). Your CV shaft and control arm angles will be ridiculous and you won't even be able to get the front end aligned properly.
Old 09-14-2013, 10:59 PM
Ramboner's Avatar
Bully's said just go with the Bilsteins up front nothing in the rear to get what I need. Ill let you know how it turns out!
