Old 09-11-2013, 01:17 AM
hand1500 hand1500 is offline
Vehicle: 2011 ram 1500 4x4
Trim Level: expess
Color: red
hand1500 is on a distinguished road
Default 4" lift adding bilsteins 5100
If I add the bilstein 5100 to my 2011 ram 1500 do I need to remove the strut spacer that was put on with the 4" lift and put the adjustment to were it needs to be or do I leave the strut spacer and just add the billstein...new to this so some good info would help thanx everyone
Old 09-11-2013, 01:43 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I'm assuming you're using the Bilsteins to level your truck with the lift installed now?
You will leave the lift strut spacer on and then set the Bilsteins to where you need them. I wouldn't go any higher than 1.4" though, you'll be pushing your CV shaft and control arm angles if you do.
Old 09-11-2013, 12:06 PM
Trim Level: expess
Color: red
I'm trying to level it and hopefully get a better ride out of it. It is so stiff in the front end its like riding a ol go kart. I mean you hit a bump and it dam near pulls the wheel out of your hand so I'm hoping these may help and thanx for the input its appreciated
Old 09-11-2013, 12:57 PM
Rep:2026
Bilsteins will definitely help with that. I had mine set at 1.4" with a 6" RCX kit and it rode beautifully. Better than stock IMO, a little more stiff but it was nice and tight like a truck should be. Definitely not uncomfortable over bumps.
To level a 4" lift you'll probably only need to set the Bilsteins at 0.7" but measuring your fender heights will tell you exactly what you'll need them at. Just remember that you'll want to retain about 0.5" of rake to avoid looking nose high.
Old 09-11-2013, 04:07 PM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2009 Ram Crew Cab
Rep:27
casper97ta is on a distinguished road
Exactly what Brandon said, Measure your fender heights to see how much rake you currently have and set the Bilsteins accordingly.
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 with trans tune - Vararam - Bully's 87mm TB - Magnaflow 14" - DeeZee Tailgate Assist - Bakflip G2- Debadged - 2500 Pocket flares - Cabin Filter - 2 12" Sundowns in Foxbox
Old 09-14-2013, 01:11 AM
What lift kit do you have and we can quickly tell you want to set them at
Old 09-14-2013, 07:18 PM
Trim Level: expess
Color: red
Thanx so much guys the info is great and the truck has a 4" lift that the dealer put on I am the second owner but the salesman said that they did all the add ons there...I just am tired of it riding so rough I just got in from my deer lease and it was terrible driving on them county "wash board roads"
