Old 09-08-2013, 11:02 PM
Rcoltey91's Avatar
Rcoltey91 Rcoltey91 is offline
Vehicle: 2005 Dodge Ram 1500
Rcoltey91 is on a distinguished road
Default 2005 heater issue
Hey guys, I've got an 05 1500 SLT. Last winter the heater was melting hot. This summer the ac was ice cold. Now the weather's Cooling down and the heater won't give me anything but a strong antifreeze smell. Floor is dry so heater core isn't leaking but the reservoir was low(so I refilled). Any ideas I live in VT can't go without a heater.
Old 09-09-2013, 12:05 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
You have a leak, my friend. Otherwise you wouldn't be smelling coolant. It may not be in the cab, but it's somewhere close. Find the leak, seal it and fill the system. I'm guessing you'll have some heat then.
Old 09-09-2013, 06:42 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:528
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Yeah my buddy had the same problem in his 2nd gen ram. He had a small leak in his heater core.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
Old 09-10-2013, 07:53 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
With stuff like this you have to know what you're doing. If you do great. Get in there and inspect it for any kind of leaks, If not for your own survival in Vermont bring it to a dodge mechanic
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 09-10-2013, 10:09 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
i had the same problem in the 98 that i had and it turned out to be a small leak in the heater core. PITA to get to.
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 09-10-2013, 10:46 PM
God Bless Texas!
Rep:2929
Listen to Astartes, he's giving you some great advice. And brondon is correct in that they are a Pain In The Ass!
Old 09-11-2013, 02:43 AM
Rcoltey91's Avatar
Thanks for the advice guys I will be checking for leaks this Thursday and if I don't find one to the mechanic it goes. I swear going to a mechanic is like letting the dentist brush your teeth. Its just weird.
Old 09-11-2013, 02:11 PM
God Bless Texas!
Rep:2929
Put a pressure tester on it. That way you can listen and look for a leak.
Old 09-11-2013, 11:10 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Feedback for this issue has me, awaiting your results (since I just bought an 05). 5.7 though.
R...
Old 09-22-2013, 10:19 PM
Rcoltey91's Avatar
Alright guys sorry its taken so long. So I've Now checked the entire system Along with pulling my entire dash to check the heater core( which was fine) come to find out I get perfectly fine heat on the passenger side. This would normally tell me blend door but I checked all the doors and motors and they were fine. Got a new lockable radiator cap to see if I was losing coolant out of there. Last resort if its not a pressure issue I'm thinking the controller panel is bad and needs replacement. At this point still only heat on passenger side and none on defroster.
