Old 09-28-2013, 04:33 PM
MrGoodbar's Avatar
MrGoodbar MrGoodbar is offline
Vehicle: 2011 Dodge Ram 1500 Sport
Trim Level: Sport Quad Cab
Color: Deep Ocean/ Water Blue
Rep:65
MrGoodbar will become famous soon enough
Hay M.Scipione,
You willing to let me borrow/ rent the 33.xx.xx and 50.xx.xx update discs from you?
I can return them once done.
Old 09-28-2013, 07:54 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I tossed them after I id the update, they are kinda useless to me after that.
I could fish them out of the trash can and send them to you but I dont know how you could tell which disk is which update.
I didnt number them or anything... just burned the first one, flashed the stereo and chucked it.
So there are 2 identical disks that I would be afraid you might do out of order.
Old 09-28-2013, 11:39 PM
Techno Tim Techno Tim is offline
Vehicle: 2012 Ram Express
Trim Level: Reg Cab Express
Color: True Blue Pearl
Rep:29
Techno Tim is on a distinguished road
Okay, add me to the “I think I’m screwed” group: started at vers 23.04.41 (RBZ) , so I burned an iso for 33-01-23 and a separate disc for 50.00.07. Grabbed TSB instructions and discs and headed out to the garage. Turned ign on, loaded the 33 disc, asked if I wanted to “Update baseline data files on HDD?” I hit YES and sat for about 15 mins, then it asked if I wanted to “Update Radio Software”, and I again hit YES. This time it got to about 20% module progress then popped up with a red disc error message and prompted me to check my disc. I hit LOAD to eject as instructed, faceplate opened, disc came out – then it immediately ate it again and closed. Ever since then it has been stuck on the Status Update screen with no progress at all. No button presses (or combination thereof) have any effect. I have tried pulling the fuse – in fact it was out all afternoon. Tried the mojo with climate controls, etc. I did manage to get the disc out and reload it, even tried inserting the 50.00.07 disc but after platter spins up, nothing ever happens. Sometimes when turning the key off and on I’ll get the RAM splash screen but then it immediately goes back to status screen.
Background: 2012 Ram Express that came with RES but upgraded to gently used RBZ about a week after I got it. Have factory Uconnect and added Mopar backup camera (dealer flashed). Have not added any files to HDD and 23.04.41 was the original software version on the RBZ.
Anyone have any ideas or is this HU a very expensive door stop at this point?
Old 09-28-2013, 11:48 PM
dmac101 dmac101 is offline
Vehicle: 2012 dodge ram
Trim Level: laramie
Rep:39
dmac101 is on a distinguished road
so i want this black screen really bad so just to make sure doing gonna ask you the steps
so go to like
log on using soxs username, clicked on my gig software update, software gracenote update- rhr rhw rhp update 2011+ - then download rhr rhw rhpiso??
is this the correct update??
Old 09-29-2013, 02:08 AM
Trim Level: laramie
Rep:39
what one would i need first this is what i have now
Old 09-29-2013, 12:46 PM
2011RamCC 2011RamCC is offline
Trim Level: Bighorn
Color: Dark Brown
2011RamCC is on a distinguished road
Well, I got the 2 updates to work, but the Travelink would not work. I had the 2 updates burned on separate discs, and the Travelink on another disc. The 2 updates worked fine (burned with an ISO burner), but the Travelink would not work. Any ideas?
Old 10-01-2013, 12:27 AM
MrGoodbar's Avatar
Rep:65
Can you burn the discs again, label them and send them to me?
Old 10-02-2013, 03:59 PM
Yqm's Avatar
Yqm Yqm is offline
Vehicle: 2012 Ram 1500
Trim Level: Longhorn
Yqm is on a distinguished road
Had the dealer do it today. Looks great!
Old 10-02-2013, 08:12 PM
JohnnyDollar's Avatar
JohnnyDollar JohnnyDollar is offline
Vehicle: 2012 Ram 1500 Quad Cab
Trim Level: Lonestar
Rep:216
JohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura about
Unfortunately you have a different radio (looks like RHR?)
and a different version of the software (2.110), so you would need a different update.
2012 Ram 1500 QC Lonestar Edition - La Bestia Defavorable
Old 10-03-2013, 01:12 PM
PJRNM's Avatar
PJRNM PJRNM is offline
Trim Level: SLT Bighorn
Color: True Blue
Rep:17
PJRNM is on a distinguished road
Originally Posted by purodude View Post
Yuuuuup. Wish I didn't. Bricked it. I removed the lockpick and it turns on and that's it. Off to the dealer I go
Wow, its very hit and miss. Ive completed two updates with the LP, and the only problem I have encountered is having to pull the fuse in the power center. When updates complete, it acts dead. I pull the fuse for a couple of minutes and after I reinstall the fuse it works perfectly.
