Old 08-30-2013, 11:15 PM
DRsilverram's Avatar
DRsilverram DRsilverram is offline
Vehicle: 2012 Dodge Ram Big Horn
Rep:56
DRsilverram will become famous soon enough
Default RCX 4 inch lift with Bilstein 5100??
Currently have the RCX 4 inch on my 2012 Ram, can I use the 5100's to
eliminate the rake, rear approx. 1 inch higher........set 5100's (in front)
at .7...........will the 5100's work with the RCX lift??
Thank You!
Old 08-31-2013, 12:05 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yup, that will work no problem. Most guys use the Bilsteins with lifts to eliminate the rake. I had Bilsteins at 1.4" on my RCX 6" kit. Worked like a charm!
Old 08-31-2013, 11:58 AM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:19
draken is on a distinguished road
Yes they will i have that exacty set up on mu 07 ram and it looks and performs great!
Zone 6" Suspension with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 08-31-2013, 07:23 PM
Thank You!
Yes you can and 0.7 will get you leveled
If you need pricing on Bilsteins, let us know
click here --->***Tuner and Muffler Sale*** <---click here
Old 09-01-2013, 05:03 PM
Rep:56
Thanks guys.....appreciate the advice......Fast, I ordered 5100's from
Bully Performance. I am thinking I will need a spring compressor to
Install those shocks. Tires to follow soon, I like the Wrangler Duratrac,
Size LT275/65/20.......34.1 inch diameter. I don't want to go too big,
Having the 3.55 gears.
Old 09-01-2013, 05:15 PM
Sweet!
That is why your username looks familiar then
As for tires....let us know when you are ready too
