Old 08-28-2013, 12:33 PM
ricroc ricroc is offline
Vehicle: 2013 Dodge Ram 1500 2wd
Trim Level: 1500 Express
Color: Metallic Grey
ricroc is on a distinguished road
Default 2WD Wheel and tire question
Hi, everyone i have a little dilemma pertaining to tires and a lift. I have a 2013 2wd V8 Express and purchased 20x9 Fuel Octanes with 1mm offset and looking to lift it with the CST 4" lift. My issue is, can i go with 35" tires or will they rub? I have called CST and they reccomend 33's and several local offroad shops that specialize in lifts have said the same thing and reccomended 295 or 285 tires. Will 33" tires look small on my truck with that size lift? Any pics with this lift and tires would also greatly be appreciated.
Old 08-28-2013, 12:40 PM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
Stock tires are 33's aren't they? If you go wider maybe they will fill the fenders out better for a wider stance.
Why lift a 2wd truck and not get a 4wd? Just curious because in the mud it will still get stuck.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 08-28-2013, 12:59 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you should easily be able to fit 35s. you could fit 35s with just a level, let alone a 4" lift.
it's really the WIDTH that you have to worry about. but you should be fine
now with the 1mm offset. if you get a tire like nitto or toyo that run wide, like over 13" you might rub a bit. but if you get a tire that runs smaller than 12.5" then i think you'll be just fine
Old 08-28-2013, 01:31 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
I think 33's or 35's will look fine.
Old 08-28-2013, 07:35 PM
SoCalExpress SoCalExpress is offline
Vehicle: 2013 Express Quad Cab
Trim Level: Express QC Rwd
Color: Mineral Gray
Rep:108
SoCalExpress will become famous soon enoughSoCalExpress will become famous soon enough
Probably the same reason I am going to lift my 2wd, looks better. If I am going in the mud I will be taking my jeep wrangler.
Custom Header Back SS true Dual Exhaust with 2 22" Maggys, De-Badged sides and blacked out tailgate emblem, Tonno Pro tri fold cover, Fold forward rear seat (extra storage is great!)
Pictures - http://s1090.photobucket.com/user/pa.../library/Truck
Old 08-28-2013, 07:37 PM
Color: Mineral Gray
Rep:108
Gonefishin nailed the answer too
Old 08-28-2013, 07:52 PM
EXPRESS25C's Avatar
EXPRESS25C EXPRESS25C is offline
Vehicle: 2012 Dodge Ram Express RCSB
Trim Level: RCSB - Express 25C
Color: Diamond Black
Rep:83
EXPRESS25C will become famous soon enough
What he said. I have 295/60/20 with just a 2" level on 0mm offset - no problems!
"Excess is Best"
Old 08-29-2013, 11:45 AM
Express25c...that is a nice looking truck. Do you have full pics of the truck and are those Nitto tires? I was told that on a 4' lift 295/60/20 would be the equivalent of running 34's. I was thinking about just going the full 35/12.5/20 with the Atturo Brand tires. Hopefully they wont rub.
Old 08-31-2013, 09:51 AM
EXPRESS25C's Avatar
Rep:83
Thanks. Yup, they are Nitto Trail Grapplers, love them. It gives the ole 2wd a more rugged look. There are some more pics in my profile's photo album. The tires I am running now are 34.45" D x 12.13" W. I am planning on getting the 295/65/20's when the current ones wear out, the 65's are about an inch taller but the same width, will put more tire in the wheel well and raise her up a bit. Good luck with your purchase and set-up, it's always fun but nerve racking at the same time when getting new wheels/tires!
"Excess is Best"
