Old 08-28-2013, 10:46 AM
1999ram318 1999ram318 is offline
Vehicle: 1999 Dodge Ram
Color: Forrest Green
1999ram318 is on a distinguished road
Unhappy Overdrive turns off while driving?
Hi everybody. I just bought my ram about a mobth ago. Last week i just got it out of the shop after having the rear end rebuilt. Yesterday i was driving and the o/d off light came on and the engined reved up real high. I cant afford to have the transmission rebuilt. Would a transmission flush with a new filter fix it? Or could it be a sensor? Anybody else have this problem?
Old 09-06-2013, 01:33 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
well it sounds like a electronic problem, the od light goes on (means od off) when the transmission gets too hot. most times the transmission doesn't really get hot enough to disable OD, so I would check the sensors the temp sensor which is shared with the governor pressure sensor i think... but fluid change isn't going to do anything. just be sure to adjust the bands when you remove the pan. the front band can be changed without pan removal but the rear band is an internal adjustment.
overdrive, transmission
