Old 08-27-2013, 07:10 PM
StuderCo StuderCo is offline
Trim Level: Sport Quad Cab
Rep:24
StuderCo is on a distinguished road
Question Adjustable Track Bar on Stock Suspension?
A friend of mine has a '97 Ram 1500 5.2. His track bar needs to be replaced. Currently, the suspension is stock. In the future, he will be putting on a lift kit, somewhere around 3-5". Are there any adjustable track bars on the market that will fit his truck at stock height, and then also after it's lifted?*Thanks very much for the info.
2013 Ram 1500 Sport Quad Cab
14" Magnaflow, Full Tint, Stubby Antenna, Cabin Air Filter, PE Jackrabbit
2007 F-350 Lariat 6.0 FX4 Crew Cab - SOLD
Studs, Gaskets, EGR del, 4" Turboback, SCT X3 w/ SPD, PHP Hercules 100, 4.5" lift, S&B Intake, Coolant Filter, Black Bumpers, 35x12.5x20", Smoked Lights, 6000k HID's
Old 09-16-2013, 01:11 AM
Rep:24
Bump...apparently I need 15 characters
Old 09-16-2013, 01:58 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
From what I've seen for adjustable track bars for my '12 3500 they will work with 0-3" of lift. I would assume that one for a '97 would work the same. Then if he does a lift it should come with a track bar drop bracket as well. Then having the adjustable track bar is nice to make sure it is 100% centred.
Check out BD Diesels adjustable track bar. To me it's the nicest on the market as you can fully adjust it with it installed on the truck.
