Old 08-29-2013, 11:40 PM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
Originally Posted by chadster21 View Post
see how long it lasts before he has issues. these ifs kits cant support that much weight those tires must be over 100 lb dry weight
Have you noticed any issues running your 37's yet?
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 08-30-2013, 12:25 AM
What chad said.
This buddy of mine had kore cvs and 38x15.5 mud grapplers and his kore cvs could not even handle all the stress and pressure those tires brought.
Seriously....37's should be max on our 1500s
Or max with the 38x13.5
Old 08-30-2013, 10:54 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
i havent had any issues yet no. but theres a big difference between a 38x15.5 and a 37x13.5. that width pulls you all over the road causing so much additional strain on your cvs. trust me if it was possible without hurting my rig i would have them on it
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 08-31-2013, 12:07 PM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2009 Ram Crew Cab
Rep:27
casper97ta is on a distinguished road
All good advice guys thanks. Ill be sticking with some 37x13.50's when its time for some new rubber. I see no need to put the front end under that much stress for a slightly larger tire.
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 with trans tune - Vararam - Bully's 87mm TB - Magnaflow 14" - DeeZee Tailgate Assist - Bakflip G2- Debadged - 2500 Pocket flares - Cabin Filter - 2 12" Sundowns in Foxbox
Old 08-31-2013, 02:08 PM
Sweet!
When you do dont add the 3" body lift as you will have too much lift for 37's
Either keep what you have or if you want more height, add the 1.25"
Old 09-02-2013, 10:13 AM
casper97ta's Avatar
Rep:27
I was wondering about that, I saw pics of your truck with the 3" BL and 37's and it kinda looked like too much wheel well for my taste but what about a 38x13.5x20 with the 3" body lift?
Also, Andrew do you have any pics of how your exhaust tips looked with the body lift on and them tilted up? Im just curious how much tilt you can get out of the tips to bring them up to the bumper.
Mods
Old 09-02-2013, 11:48 AM
Nah, even with 38's it's too small.
It's only 0.7" larger in diameter. So really 0.35"
Makes no diff
I would have dropped the Bilsteins and removed the rear coil spacer if I kept it on and ran the 38's I had
Here is it on 37's and 11"+ lift
Here were the 38's that were going to go on that went to a body along with the lift
As for exhaust....I had mine fixed.
Here are some before and afters.
Gotta cut this and weld it
After cutting
Tips lined up
