Old 08-27-2013, 05:40 PM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2009 Ram Crew Cab
Rep:27
casper97ta is on a distinguished road
Default Fitting 38's with 8" of lift?
Im running 36's now and came across a fantastic deal on some 38x15.50x20 Toyo MT's and wondering if anybody has run 38's with 8" of lift? I know a lot of guys are running 37's so I dont think there would be much rubbing if any. The extra width of the 38's over my 36's is the main concern, Ill be running a 2" wheel spacer also so im hoping there should be enough clearance. Any thoughts?
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 with trans tune - Vararam - Bully's 87mm TB - Magnaflow 14" - DeeZee Tailgate Assist - Bakflip G2- Debadged - 2500 Pocket flares - Cabin Filter - 2 12" Sundowns in Foxbox
Old 08-27-2013, 06:00 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The width is definitely what I'd be concerned about, not the height. I don't have first hand experience but if I had to guess I'm going to say you're going to hit your front bumper and the back of your fender when you try and turn.... What will your total backspacing/offset be with your wheels and the 2" spacers?
Old 08-27-2013, 10:42 PM
BuckWild09's Avatar
BuckWild09 BuckWild09 is offline
Vehicle: 2007 Dodge Ram 1500 Hemi 4x4
Rep:63
BuckWild09 will become famous soon enough
I definitely think youll rub no matter what like Brandon said.
Toyo mt38x15.5 are actually 15.9"
To even be close to running those Id think youd need a body lift
3" Zone Body Lift--6" RCX-- Bils @ .5"-- 20x12 Fuel Hostages--37x13.5" Toyo MT
Old 08-27-2013, 11:14 PM
Brandon Snyder's Avatar
Brandon Snyder Brandon Snyder is offline
Vehicle: 2007 Dodge ram 1500 Hemi
Color: flame red
Rep:13
Brandon Snyder is on a distinguished road
agreed on body lift you will need one
True dual flowmasters, 2 12 in Memphis, kicker door speakers, Kenwood head unit , 2.5 ready lift level, 33in mts, fuel hostages 17, Afe cai, bbk 85mm throttle body, weathertech floor mats, Aries bull bar , 2 kc off-road lights, superchips 3865.
Old 08-27-2013, 11:28 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
10'' of lift 37'' toyos which measure 14.3 or something in width and i rub at times. you will not only rub but youre going to destroy your front end with that wide of a tire on a half ton. none of my business what you do but i dont recommend it
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 08-28-2013, 01:02 PM
casper97ta's Avatar
Rep:27
Thanks for the info guys, Thats kind of what I thought. Theres a guy local to me selling 3 of the Toyos with about 10/32 tread left for $150 for all 3. You can see why its tempting the hell out of me to pick them up. Ill probably just hold off and pick up some 37x13.50's down the road. In the long run its probably not worth the added stress on the front end and have to do a bunch of trimming due to the rubbing.
Mods
Old 08-28-2013, 09:49 PM
chadster21's Avatar
Rep:108
good thinking..........
Old 08-29-2013, 05:17 PM
For no rubbing...you will need maxed bilsteins, 1.25" body lift and 6" RCX lift and then you need the proper offset.
So basically as Chad mentioned, you will need 10"+ lift.
But there is a member who fit it on his truck with what I mentioned above.
However he has 20x10 -12 vs -24
But it is kinda wide and heavy
Stick with 37x12.5 or 13.5
Old 08-29-2013, 05:48 PM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
My buddy is running 38x15.5 mud grapplers with 6" rcx, billsteins and 3" body lift on 20x12 -44's. Pretty sure he doesn't scrub at all but that's also 10+ inches of lift depending where he has his bilsteins set.
The truck is massive and looks a way bigger than it did with 37x12.5's. Put a 3" body lift in and go for it!
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 08-29-2013, 10:52 PM
chadster21's Avatar
Rep:108
see how long it lasts before he has issues. these ifs kits cant support that much weight those tires must be over 100 lb dry weight
