Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-27-2013, 01:03 AM
renman1972's Avatar
renman1972 renman1972 is offline
Vehicle: 1985
Trim Level: Base
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
renman1972 is on a distinguished road
Default Junkyard tranny swap
I have an 85 Ram that I have successfully swapped the tranny on once.
Recently the tranny oil cooler went bad giving me the dreaded 'strawberry milkshake' in the transmission. When I swapped it the first time, the donor tranny was from an 86 truck. This time I have found a transmission that has electronic overdrive. This did not come standard on my truck. All the bolt hole seem to line up and the donor is the same size. So, I guess my question is, will it work ?
Any help appreciated
Old 09-06-2013, 12:38 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:127
if you need the OD to work you can just wire a switch in the dash to enable and disable. somewhere on the internet is a little instructional with pictures to do this.
Old 09-09-2013, 02:19 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Depends. It will work if from a truck '95 or earlier. 1996 and later will bolt up, but need a computer controller. If a pre '96, all your linkage will bolt up. You will need a shorter driveshaft and at minimum, an simple on/off switch for the OD.
junkyard, overdrive, transmission
