Old 08-28-2013, 08:03 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Originally Posted by TTaylor34 View Post
Is anyone out there running bilsteins at 2.8 with a 1" or 2" rear spacer with no other lift? if so what kind of height did you gain? thanks!
Well you're going to gain 2.8" on the front and 1" or 2" on the back......
Old 08-28-2013, 08:15 PM
TTaylor34 TTaylor34 is offline
Vehicle: 2013 Dodge Ram 1500
TTaylor34 is on a distinguished road
Well that was simple then lol the reason i was asking is ive read some threads on here where the front will settle or the 1" spacer will only actually gain .75" I do appreciate the quicl reply though
Old 08-28-2013, 08:29 PM
Rep:2026
Haha, no worries man. Just giving you a hard time.
Typically the front will settle slightly... but it will be practically unnoticeable. Less than a 1/4". A back spacer should provide you with the exact amount of lift as advertised.
Old 08-28-2013, 09:00 PM
I appreciate the help! I have a 13 Ram sport CC 6 4 box and originally wanted a 4" lift, however if i gain exactly 4" or more it will not fit in my garage. (which is not the end of the world however it is nice to get it out of the NY winter occationally) So i was looking for the next best option to gain as close to 4" as possible aside from a body lift. Any input is much appreciated.
Old 08-28-2013, 09:10 PM
It will settle....but only about 0.1-0.2" and the rear if you get the proper rear coil spacer should be exactly what you bought as its solid steel
