Old 08-24-2013, 07:36 PM
vanip vanip is offline
Vehicle: 2012 ST 4X4 Regular Cab
Rep:37
vanip is on a distinguished road
Default Bilsteins at 2.1 or 1.4?
Bilsteins coming soon. Would like to do 295/60/20's in an All terrain tire. 285/65/20 would be second choice, a tad taller. Measurements of wheel well to ground right now are:
36 and 7/16's FRONT
38 and 13/16's REAR
So keeping that in mind should I do 2.1 setting or 1.4? I haul snowmobiles so having at least 1/2 rake is fine but a 3/4 rake would be best. That is why I am considering 1.4 setting. I want to fit 295's w/out too much trouble. American Racing Circuit 20x9 rims with offset +15 and hubcentric adapters currently on vehicle. Thanks in advance-yes I've searched but thought someone might have an opinion due to my specific specs!
Old 08-24-2013, 11:01 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
1.7 isnt a setting. 2.8...2.1...1.4...0.7...0
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 08-24-2013, 11:16 PM
Rep:37
Sorry-not sure how I got that. Guess 2.1 is pretty much the way to go as 1.4 would not be enough...assuming those are roughly inches of lift. Thanks for the correction. I fixed the post accordingly.
Old 08-25-2013, 01:41 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I would personally suggest 2.1 or 1.4, most who are just using them for a leveling kit will go with 2.1 however if adding them to a lift kit for some additional lift some will use them at 1.4 with no rear spacer or a 1/2" spacer depending on what kind of rake they are looking for or 2.1 and a 3/4"-1.5" rear coil spacer.
The ride quality will be better at 2.1 then it is at 2.8 for sure, and the few I have spoke with that have gone from 2.1 to 1.4 say 1.4 is even better that 2.1 is. Most will agree that with bilsteins at 2.1 or 1.4 it is better than factory ride
Thanks
Jeremiah
