Old 08-29-2013, 05:36 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
FYI, it's on sale at Amazon.com for $558, about $200 cheaper than everywhere else
http://www.amazon.com/Ground-Force-9.../dp/B004Q5HJDG
Old 08-29-2013, 11:23 PM
I push the skinny pedal
Rep:3277
Gotta remember it's STILL a 4x4,
If you want to risk screwing up a couple $800 CV shafts,
by all means drop it lower by using a drop spindle.
I don't know where you're buying your CV shafts, but $800 is ridiculous! I just bought a new pair for $130 shipped to the border. That said, dropping the front of a 4wd with spindles will play merry havoc with the inner CV joint and put some extreme angle on your upper control arm/ball joint; I've done that very thing and I've already snapped one inner CV joint. There is a solution to getting low with a 4wd, and it involves a new set of upper control arms (Michigan Metal Works $500) and new porche 930 inner CV joints (Kore $800).
Out back I used the 2wd McG's springs and it brought me almost 5" closer to mother earth, and at that point you really need adjustable control arms and panhard bar (Spohn $700). You have to ask yourself if $2K is worth getting that low and maintaining 4wd.
I have talked to Mike at L&M and he says you can use the 2WD stock spindle for a 1" drop on the front without CV issues. It's another option out there if you want to go a bit lower without spending the extra.
Kurtis
Old 08-30-2013, 11:37 AM
Rep:554
I've never had to buy new CV shafts, I have a Ground Force kit
But "IF" I ran a 2.5" drop spindle and broke the stock inner CV clean off
...I Certainly wouldn't replace it with the same thing
How much did you say the upgrades cost you? certainly not $130
I'm not sure the OP is looking for that much of a drop, and the added cost involved.
But I could be wrong
Old 08-30-2013, 10:20 PM
Rep:3277
I've got the GF front springs AND the spindles, I've always wanted to be closer to mother earth.
I bought new CV shafts so I can have a new ones to work with when I put the Kore inner CVs on. The new CVs axles ordered from rock auto were $130, the replacement inner CV joint kit from Kore is $800.
Most people aren't as crazy as me to go this low on a 4wd, but I only had a 2/4 on my '07 and I always wanted it lower. Most are satisfied with the 2/4 on a 4wd, but as you can see from the rest of my build, I'm not normal... especially in the head
Kurtis
Old 09-01-2013, 04:02 AM
BiggBoy BiggBoy is offline
Rep:98
BiggBoy will become famous soon enough
Just bought it thank you
368hp@wheels and counting
Old 01-25-2014, 06:03 PM
Thumper's Avatar
Thumper Thumper is offline
Vehicle: 2012 Ram 4x4
Color: Flame Red CC
Thumper is on a distinguished road
Love the stance! This is the exact look I am hoping for. What model/size are your Nitto's?
K&N CAI - Magnaflow Y - Borla Pro XS - Debadged - Cabin Air Filter - Parachord Interior Wrappings.
