Old 08-22-2013, 07:39 PM
taildragger taildragger is offline
Vehicle: 2011 Dodge Ram
taildragger is on a distinguished road
Question Both Passenger Headlights Out
I just noticed that both headlights on the passenger side are out, is it just a coincidence or is there something else I should be looking at before pulling and looking at bulb replacement such as an error code or anything? Anybody else had this issue?
Old 08-22-2013, 09:05 PM
moparornocar72's Avatar
Rep:630
I would check the fuses but in the past it has been known for the tipm to cause this problem. If the fuse is okay you will have to take it to the dealer and hopefully it's under warranty! Good luck!
14.268 @ 95 MPH Full Trim
Old 08-26-2013, 11:32 AM
I took it to the dealership on the weekend and they found the problem. Turned out to be an improper install by an auto truck shop that did the install when I upgraded to PIAA's. (one of the pins @ the connector had gotten bent) I guess you get what you pay for! Dealer hit me for $70, but at least it's fixed.
Old 10-27-2013, 05:18 PM
ABCRUDE's Avatar
ABCRUDE ABCRUDE is offline
Vehicle: 2011 Ram
Trim Level: SPORT
Color: BLACK
ABCRUDE is on a distinguished road
i had a problem with driver side after installing ANZO Ubar lights. turned out dodge has a problem with their wiring harnesses. connectors do not make a good connection. went out and bought aftermarket connectors for H9 BULB. cut off old and soldered new connector to harness. its been 3 months no issues
hope this helps
LIFE HAS A TON OF CURVE BALLS
YOU JUST HAVE TO LEARN
HOW TO HIT THEM
