Old 08-21-2013, 05:44 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Could new wheels help?
I got 275/65R20 duratracs on my stock wheels and i wish they stuck out a little more than they do. I know I could have gotten wider tires, but thats not an option now. If i get new wheels and got a 0 offset or something like that will it bring them out a little bit?
Thanks
Old 08-21-2013, 06:10 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Yes, wheels with a more negative offset will make your tires stick out further. How much further do you want them out?
Old 08-22-2013, 12:18 AM
Trim Level: express
Rep:43
about an inch and i do want to be able to fit a 295 width tire (without using a spacer) later when these wear out.
Old 08-22-2013, 12:41 AM
Rep:2026
You'll probably want a 20x9 0 offset then. You should be sticking out almost exactly 1" with those wheels and a 295 tire.
Old 08-22-2013, 02:04 PM
Trim Level: express
Rep:43
What about a +1 off set will i be able to fit a 295 tire no problem? Also will it look weird with the tires i have now?
Old 08-22-2013, 02:06 PM
Rep:2026
+1 offset is literally 1mm difference from a 0 offset, so it's essentially the same thing. You won't have any issues with that set up.
It should look fine with the tires you have now too.
Old 08-22-2013, 04:58 PM
Trim Level: express
Rep:43
Great thanks so much for the help as usual lol!!!
Old 08-24-2013, 12:50 AM
fastNugly @ BP fastNugly @ BP is online now
This ^^^ is what I'd recommend too
Did you have a rim in mind that you'd like pricing on?
We deal with all the major brands
Let me know if I can help you out.
fastNugly@bullysperformance.com
Old 08-25-2013, 11:08 PM
Trim Level: express
Rep:43
Yeah i was checking out the fuel trophy wheels. The matt black ones, in the +1 offset and 20x9.
Old 08-25-2013, 11:33 PM
We can get those for you.
Send me an email and I can provide you pricing
