Old 09-23-2013, 03:00 PM
FASTRAMRT's Avatar
FASTRAMRT FASTRAMRT is offline
Vehicle: 2012 Ram RT
Trim Level: R/T
Rep:34
FASTRAMRT is on a distinguished road
Never even thought about the wrench cutting technique..�� that would have saved a lot of pissing around.
~RobbieB~
Old 09-23-2013, 04:50 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Originally Posted by FASTRAMRT View Post
Who is l&m? I can't find there contact info anywhere on the web. ...
L&M Customs out of Delaware, small performance shop that has no website.
Mike (MGH is his member name) the Owner of L&M,
is the one who built the OP's (ironchef2011) 2012 R/T custom suspension and did his 6.4L Crate Motor swap.
He also re-builds enhanced boost-proof transmissions for 4G Rams
So far I think he's put almost a dozen of us on the road that are running Turbo's and Superchargers.
You wont find anything with Google, use the ramforumz seach engine
MGH's Twin Turbo Build: http://www.ramforumz.com/showthread.php?t=83155
Varoius transmission threads:
http://www.ramforumz.com/showthread.php?t=141021
http://www.ramforumz.com/showthread.php?t=146929
I'm not sure his transmission builds are suited to NA applications though,
it would likely be overkill and his tuning that's included would need a revision for less HP/TQ.
Old 09-23-2013, 05:53 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Well 3 transmissions ill add a damn super charger then lol
Old 09-23-2013, 06:02 PM
InDeepWaterBlue's Avatar
Rep:611
As far as the shock bolt lol its easy just cut an open end wrench and that solves the problems
I wish I had anything that could cut it, be it an angle grinder or a fricken torch lol I had to use a regular wrench length wise, and then a pair of vise grips wedge against the bed to keep it from slipping lmao I went and bought a set of crows feet after that debacle.
As for the OP's truck set up it looks great, and I'm debating putting a set of those RideTech spring on my truck. I like the idea that I could lower it more if I wanted for shows, corner balance the truck, and lift the back end more if I was going to be towing/hauling. You add that setup with a simple airbag on the axle and you would have a great tow rig.
Old 09-23-2013, 09:13 PM
FASTRAMRT's Avatar
Trim Level: R/T
Rep:34
Thank black ram hemi for the info, I was losing my mind because I couldn't figure it out lol all in ever seen was l&m this and l&m that but kept coming up with nothing haha and In Deep I used a socket that barely fit wit a long extension. Got the job done but dam was it ever tricky. Could have used the proper tools but my problem was it was the long weekend everything was closed and I was impatient lol. Anyone know if a panhard bar would cause rear death sway if it was out of place? Iron chef is gonna help with my suspension parts thank god.
~RobbieB~
Old 09-24-2013, 01:31 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
you dont have a hacksaw lol
Old 09-24-2013, 01:32 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
i had the death wobble at 70 put on a sphon adjustable bar and it went away
Old 09-24-2013, 01:47 PM
Rep:611
somehow, no lol
same here, spohn bar adjusted properly and the truck rides nice and smooth again
Old 09-24-2013, 08:12 PM
FASTRAMRT's Avatar
Trim Level: R/T
Rep:34
Pan hard bar upgrade it is lol the first time I got the death wobble it scared me.
~RobbieB~
Old 10-14-2013, 09:56 AM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2012 Ram Express
Rep:15
Fasthemiram11 is on a distinguished road
Mike, let me know if you need the stuff for a 2010 PCM swap. It was nice talking to you.
2012 SOUTHERN EXPRESS
Had 2011 HEMI EXPRESS 12.4@111
