Old 08-24-2013, 04:35 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
Very nice work. If you're using the McG's spindles I'm surprised Mike's still using a balljoint for the upper control arm and not something with more movement like a uni-joint or spherical joint. I have no doubt that he's worked the geometry, but you just have more leeway with either of those two options.
Kurtis
Old 08-24-2013, 12:35 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
Originally Posted by ironchef2011 View Post
I really don't haul or tow anything of consequence so it's fine for me. We'll be adding bump stops and/or air springs in the stock coil area though just in case my usage changes.
Simply awesome MIke looking forward to some more pics once you get her back
Old 08-24-2013, 01:03 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Thanks Sonny! One more week until I pick her up!
2012 R/T 392
Old 08-25-2013, 08:54 PM
Klrpanda Klrpanda is offline
Vehicle: 2009 Dodge Ram
Klrpanda is on a distinguished road
do you like the coil overs? and do you have a part number on them?
2009 RC Hemi-Edge 3000 Stall, AFE CAI,Diablo Tuner, CMR Tuned, 2011 R/T Axle 4:11 Gears, E-Fan
Old 08-25-2013, 09:24 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
No clue my friend as the truck is still at L&M being tuned and finished. I don't pick her up until next weekend but I'll be sure to post the results good or bad.
One note: The SRT8 Brembo calipers did not improve braking results whatsoever. Mike and I said from the start that anything that doesn't have a function will not remain on the truck. So, as good as they looked, they will not stay on the truck.
2012 R/T 392
Old 08-25-2013, 09:41 PM
Rep:3277
Have you thought about installing a hydro-boost system to really take advantage of the better braking ability of the Brembos? The higher caliper count of the Brembos would perform much better than the 2 caliper OEM system when you're actually pushing 3 times the hydraulic force of the vacuum booster. The swap is dead simple and would really benefit you.
Kurtis
Old 08-25-2013, 09:52 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
To be honest, brakes scare me. I have no problem swapping motors, screwing around with suspension and I've even chopped tops. But messing with brakes that aren't bolt on kits? Not for me, and I have to say that I've always been super impressed with the Ram braking from stock.
That being said, with some more work they would probably make a killer setup.
2012 R/T 392
Old 08-25-2013, 10:14 PM
Rep:3277
The hydroboost system is what's used on the diesels, and you can buy the complete system and it bolts right in place. I just picked up the booster, master cylinder, and hoses for $125 from a wrecked 2500 at a junk yard.
Kurtis
Old 08-26-2013, 05:36 AM
autobred's Avatar
Trim Level: R/T
Rep:142
how did you guys test the brakes? Typically the brakes will feel the same on initial stops. its the improvement in brake fade/handling of heat is what you're after. Do they take bigger brake pads than your oem?
Old 08-26-2013, 05:46 PM
C to the J's Avatar
C to the J C to the J is offline
Trim Level: R/T
Color: True Blue Pearl
Rep:36
C to the J is on a distinguished road
Crazy amount of work, but it's gonna be insanely awesome. You'll be able to build another RT out of all your used parts soon lol.
