Old 08-19-2013, 03:05 PM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Sounds like low refriderant (freon is no longer used)....those pressures seem awfully low.
on a side note, the system is filled according to weight of the refridgerant....not psi. so it wouldnt hurt to have a shop evacuate, put the system under vacuum (check for leaks) and recharge to correct amount. so that variable is not in play in the diagnostic game...
Old 08-19-2013, 04:22 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Biker has a point. One less thing to trouble shoot while trouble shooting. I'm thinking the TPS is outta whack. When you mash on go pedal, the TPS is sending a false signal to the puter, and the puter shuts down the A/C thinking you want more power.
Old 08-23-2013, 08:49 AM
tjbiker031's Avatar
Rep:118
I doubt that is true. The compressor is controlled by temperature and pressure sensors via computer control. Now it could be a bad control module, but doubt it. Get everything evacuated, and recharged. It its still not working properly then a component (such as a orifice tube) may be bad.
Honestly, unless you totally understand how the system works, it should be taken to a professional and properly diagnosed. $500 in diagnostic,parts and labor is way cheaper than destroying a $4,000 a/c system
