Old 08-17-2013, 03:48 PM
soupbowl soupbowl is offline
Vehicle: 2004 Dodge Ram 2500
Color: Deep Molten Red Pearlcoat
soupbowl is on a distinguished road
Question AC blow warm/ humid air during normal acceleration
2004 ram 2500 5.7l with climate control ( driver & Passenger slide temp controls) Ac works fine while truck is idling but during normal acceleration ac blows humid air, checked freon low pressure side it is @ 35 psi @ 75degrees on the AC Pro fill gauge. I think it might be a vac leak but dont know where to start checking or if it might be something else???
Old 08-17-2013, 05:59 PM
Trim Level: sport
Color: green
Rep:643
is the electronic fan cutting out?
Old 08-17-2013, 07:05 PM
no electric fan keeps running, ac seems fine when I rev it in park, but it happens when truck is moving....
Old 08-17-2013, 08:59 PM
Trim Level: sport
Color: green
Rep:643
i haven;t a clue then. answering so this gets back to the top so an ac expert can jump in.
Old 08-17-2013, 09:12 PM
thanks for trying....
Old 08-17-2013, 09:26 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Your A/C is not working properly. Anything else you want to know? After checking all fuses, you would be advised to go to the dealer or a reputable A/C shop.
Old 08-18-2013, 06:43 PM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
Good luck with that. My boss's cummins 2500 does the same thing. We have had it apart God knows how many times. I wonder if they have a ac comp. cut off thats linked to throttle position. Maybe its getting a wrong signal. His will freeze you out and put water on the outside of the glass even here in Arkansas. If you are on the throttle beyond "normal" it cuts off.
Old 08-18-2013, 08:09 PM
Trim Level: sport
Color: green
Rep:643
sounds like a trip to the dealer is in order.
Old 08-18-2013, 08:11 PM
Trim Level: sport
Color: green
Rep:643
before you head to the dealer. brush some soapy water on all ac hoses and fittings. leaks might show up when things expand.
Old 08-18-2013, 10:17 PM
skytop's Avatar
Rep:420
I seem to remember something like this happening with a Volkswagen my wife had. It turned out to be the ECU.
The ECU cuts the A/C to give more power under heavy loads. The service department determined that the loss of A/C while under acceleration or operating under load and the condition was 'normal' for the car.
