Old 08-16-2013, 01:36 AM
tosh tosh is offline
Vehicle: 08 ram 1500
tosh is on a distinguished road
Default 08 ram running hot
ive had my 08 ram 1500 5.7 hemi for three years and never had an issue with engine temp, it recently has been running about 3/4 or hotter on the gauge(ive never seen it move from normal operating temp except when towing). Ive replaced the fan and thermostat at the dealer(warranty) but that hasn't worked, the temp never gets into the red and eventually goes back to the normal operating temp. Help!
Old 08-16-2013, 03:15 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
If the fan and t-stat were replaced under warranty, why not have them fix it under warranty, or at least replace the radiator? Anyway, if it goes back to normal temp, it sounds like the t-stat is sticking.
Old 08-16-2013, 09:58 PM
t-sats and fan was replaced on warranty, dealer says its probably air in the system and to drive it a bit, the air will work it self out, thanks for the help. If it was my money paying for the work i guess i could be more pissed.
Old 08-18-2013, 03:18 AM
God Bless Texas!
Rep:2929
"The air will work itself out". Huh? Air don't works itself out. You, or I should say the dealer, needs to bleed it and then add coolant.
Old 08-18-2013, 05:10 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
^^^ sounds like good advice to me. roger knows what he is talking about. the cooling system is a sealed system. if there is air in there it won't magically disappear. you could try running it up to temp with the rad cap off and see if the coolant level drops. if there is air in the system it will drop after the t-stat opens and it pushes the air out. do you have heat inside the truck? are the heater hoses hot when its at normal operating temp?
Old 10-04-2013, 01:08 AM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
One way to help get rid of trapped air is park the truck on a sharp upward incline. remove the rad cap and run the engine for a long enough time to get the temp running hot and it should help to burp the air out of the system. Good luck.
Old 10-08-2013, 10:13 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
with the truck parked on an incline have someone hold the rpm at 1500-2000 while you have the rad cap off and add coolant. when you let off some will spill out the top and you'll know it's full.
Side note, I have these same symptoms, but I know my problem is a clogged radiator.
