Old 08-15-2013, 03:01 PM
j3andit j3andit is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express 4x4
Rep:18
j3andit is on a distinguished road
Default BDS/bilstein question
next week im buying the 4inch BDS lift with the 3inch coils in rear. im also putting the bilstein 5100s up front. what setting should i have them at. ive been told by some that 0.7 and 1.4 are common but 2.1 will be closest to level. what you all think
Old 08-15-2013, 03:03 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I'm pretty sure the guys who run RCX go 1.4 to get level. I'm not sure about BDS.
Once you get perfectly level, it appears to sit nose high. So i would say go with 1.4
Old 08-15-2013, 03:12 PM
Since you will be going with a 4" BDS lift and a 3" rear coil you will want to set them at 1.4 to be near/deal level depending on your current rake
2.1 will set you nose high, but then you can easily throw on a rear coil spacer.
However, the ride on 1.4 is REALLY good compared to 2.1
I know as I went from max, to 2.1 and to 1.4
2.1 is good, but 1.4 is better. Plus your CVs are still good.
I know we have spoken about lift kits....if there is any further questions I can address let me know
Old 08-15-2013, 03:13 PM
Due to the 2" rear block provided with the kit. 0.7 will set you level.
1.4 will give you a slightly nose high measurement and look. Plus you cannot add a rear coil spacer on top of another.
So you will need to either grab a 3" rear coil or get a larger coil spacer (which isn't a huge deal)
Old 08-15-2013, 03:15 PM
Rep:1900
there's your man ^^^^^ Andrew knows.
Old 08-15-2013, 04:38 PM
fudrock's Avatar
fudrock fudrock is offline
Vehicle: 2012 Ram 1500 4x4 CC
Color: True Blue
Rep:133
fudrock will become famous soon enoughfudrock will become famous soon enough
Just had this exact kit installed last weekend (pics soon!). Are you upgrading your rear shocks? I think you should. You're already this far...
Anyway, tech set mine at 2.1 and said I was sitting dead level at the fenders. I didn't get a chance to grab a tape and get a measurement myself but visually it looks level, though, and I think it's because I have the sport hood, it does appear a tad nose high depending on how you look at the truck. I'm giving everything a chance to settle, but I'll probably wind up having him drop the bils to 1.4 when I go back in to have everything retorqued.
What is your rake like now? I had 3.25" of rake at stock.
Not to stoke your fire as I was in your shoes a month ago but; you're gonna ******* love it when it's done
PS: Just listen to whatever Andrew says.
4" BDS Lift Kit w/ 3" Rear Coil Springs and Fox Shocks - Bilstein 5100 Shocks @ 2.1 - 20x9 XD Badlands -12 Offset - 35X12.50 Mickey Thompson ATZ - WeatherTec Digitalfit Floor Mats Front and Back - Bakflip VP - 18" Magnaflow Exhaust - Debadged - Smittybilt/NFAB Stainless Nerf Bars - - Bully Dog GT - 2013 OE Projectors - Cabin Air Filter
Old 08-15-2013, 04:50 PM
Just to the OP, the reason why fudrock set his to 2.1 and is level is because he had 3.25" rake.
With just the lift alone his rake would have been 2.25" and it makes sense that 2.1 will level it.
If your truck follows the standard and avg 2.75" rake 1.4 will be your setting.
But pls do measure your fenders (front and rear) and make sure your truck is parked on flat of a surface as possible.
Mike, once your Bilsteins settle (about 0.1-0.2") you may not want to drop them down.
Based on that teaser you sent me, I think you will be even more pleased once settled.
Old 08-16-2013, 01:18 AM
Rep:18
ok thanks guys. i will get the measurements and re confirm with you. and fudrock i wanna see pics!
Old 08-16-2013, 12:49 PM
10-4 and I too want to see his pics
Old 08-16-2013, 03:22 PM
Doc M's Avatar
Doc M Doc M is offline
Vehicle: 2012 Ram
Color: True Blue
Doc M is on a distinguished road
Since I am going to walk this same rope very soon I have one question.
Is that with the BDS spacer or without it?
