Old 08-13-2013, 03:23 PM
Wartowne Wartowne is offline
Vehicle: 2013 Ram 2500 4wd
Trim Level: Longhorn Laramie
Wartowne is on a distinguished road
Default 2013 Ram 2500 4WD issue
This is my first post here.
I have a 2013 Ram 2500 4WD diesel. I have right at 2,000 miles to date.
I put larger wheels and tires on a week after purchase LT295/70R18
I also had a MAXX suspensions 2 inch leveling kit installed and realignment done. The truck drove great and looks great.
The other day, while backing out of my driveway, something in the driveline made a very loud metallic clanging and then the truck did not want to move. Trying to back up and turn out of my driveway, it felt as is the 4WD had engaged and felt like trying to drive on DRY pavement. There were no indicator lights that the system was engaged.
The other symptom was going from park to drive, the truck did not want to move as if the brakes were engaged. I have a flat driveway and am fully aware of the hill-start assist.
I parked the truck and had a friend come over. He maneuvered the truck around while I inspected. Nothing was rubbing or interfering as inspected.
The wheels were literally shimmying as we would maneuver the truck in the driveway. We engaged the 4WD and let it cycle thru engagement to see if that would release the front wheels. It did.
Following that, I drove the truck around 20 miles. Come back home and BOOM, sounded like the transmission fell out of the truck! It was bad. At that point I called a tow truck and had it hauled to the dealership.
To sum it up, of course the service dept said that they could not get the truck to repeat the symptoms and gave it back to me. They didn't even crack open the front diff. The service guy told me that the bigger tires not being programed into the computer and the "non-Mopar" leveling kit could be the issue and that they had a Wrangler that had bigger tires that caused 2nd gear to burn out.
Of course, my response to the service guy was "BULL $HiT"
I have the truck back and will hopefully be able to capture this phenomena on my iphone as evidence the next time it happens.
Can anyone with technical expertise give any credence to the service dept's claims?
Old 08-13-2013, 04:06 PM
edge35's Avatar
edge35 edge35 is offline
Trim Level: Laramie Longhorn 4x4
Rep:70
edge35 will become famous soon enough
Wow, his back must hurt from carrying that load of crap around. If larger tires did that then then the streets would be littered with broken down Wranglers since bigger tires are practically a rite of passenger for Jeep owners. Besides having to exert itself by turning a heavier tire it seems like the only real issue a truck would have with larger tires and no adjustment in programming would be the speedometer being off a bit. Granted, this is assuming you aren't running some ridiculously oversized Bigfoot tires that weigh a gazillion pounds...and from the size you listed that isn't an issue. I ran 35" BFGs on my 2010 Rubicon without issue, and compared to your diesel my Jeep's 3.8L was about as powerful as a baby rat fart.
Perhaps a different dealer should take a look at it.
PS Welcome to the forums!
2013 Laramie Longhorn 4x4
6 speed (although the 65RFE is really a 5 speed), 3.55, air suspension, anti-spin, 20" Goodyear Wrangler SRA tires (aka crap), sunroof, Bakflip Fibermax & BakBox, bed extender, 8.4AN, black/cattle tan interior
Old 08-13-2013, 04:10 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:532
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Yeah man, I don't think your 3/4 ton has a high enough payload rating to haul around the load of bullsh*t he gave you.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread).
Old 08-13-2013, 04:37 PM
I'm curious if leveling the truck could somehow cause the Hill start assist to think the truck is inclined and therefore try to engage the brakes.
Like I said, I cant envision how slightly larger tires would cause these issues.
Old 08-13-2013, 04:55 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
Well even if the hill start assist did anything it only lasts for a few seconds. It disengages once you hit the gas.
Sounds like something more is going on here.
Chrome... in moderation.
Old 08-13-2013, 05:31 PM
Agreed. I'm just praying I don't have a random software phantom.
Old 08-14-2013, 12:28 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
If I remember right from my manual, the hills start doesn't even kick in unless you are at a 7% grade or more. The level kit couldn't have changed it that much. It sounds like you have a mechanical issue (transfer case, differential, axle, etc). With it happening twice already, the next time will probably leave you stranded somewhere when it grenades.
Old 08-14-2013, 11:38 AM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
transmission shifting isn't based on wheel speed. It's based on the speed of the transmissions output shaft. Speedo is done with the ABS sensors... Because of these 2 reason is the reason why if you swapped your gearset out, you don't need to program anything into the computer....
If something in the transmission popped, it's not because of the tires...
BTW, if cycling through the 4WD selector fixed the problem for 20 miles, I'm thinking it's something in the transfer case.
4wd, issue, tranny, wheels
