Old 08-12-2013, 10:41 PM
NCBEAST NCBEAST is offline
Rep:16
NCBEAST is on a distinguished road
Default Tailgate light bar and install
I have been wanting one of those long LED tailgate light bars for the longest time. I started doing some research and there are tons of reviews and how unreliable they are. After a little while they get moisture in them and the LEDs start to fail. I have finally decided to get this one.
http://www.customdynamics.com/truck_led_light_bar.htm
It is a little more expensive than others and even has fewer features than some (no sequential turns or white reverse lights) but it seems to have more LEDs than others so it should be brighter. It is in a rigid aluminum casing and has a lifetime warranty for LED failure. I have used these guys in the past for LED strips for my Harley and they have really been great. I have emailed them over the past couple of weeks and they have always been very responsive. I also ordered this so I would not have to tap into the factory wiring, can hide the connection and leave the 4-pin on the bumper available for use.
http://www.ebay.com/itm/140958989430?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
Now I just have to figure out how I am going to install this thing. So we have the spare tire access hole right in the way. I know you can remove the plastic ring around the hole and mount the light bar just covering about a quarter of the top of the hole and can still access enough of the hole to get the extension in there. But if you look you really need to mount the bar right over the hole for best light output. Also this bar only uses automotive 3M tape to install. I have used this stuff before and have no problem with it and know it will hold up well. But you better make sure you have it straight and level the first time because you really only get one shot.
So I started thinking how I could cover the spare tire access hole up and figure out another way to lower the spare tire when needed. Then I thought it would be great if this light bar was just magnetic on the back and you could mount it anywhere and remove it when needed. I started researching some of that magnetic tape and all of the reviews for that stated that it is not very strong. Then I thought about just getting some magnets and using the 3M tape (that comes on the light bar) on the back to adhere the magnets. I found some of these on eBay but have not ordered them yet. The light bar is also 3/8” high is why I am looking at this size but the longest I can find is 1” so will need to use several of them, not really sure how many. That will have to be trial and error, will start with three and add more if needed. I did make sure with CD that the magnets would not affect the LEDs.
http://www.ebay.com/itm/271150412558?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1438.l2649#ht_1773wt_800
I know they are little expensive for 10 small magnets but it may be worth it if it makes the light bar easier to install and removable. The problem I am worried about with these is that with their holding power and smooth finish that they could just pull off of the 3M tape and stay on the truck…..
Please help….need any other advice or suggestions.
Thanks,
Greg
Old 08-13-2013, 12:29 AM
Cat Daddy's Avatar
Cat Daddy Cat Daddy is offline
Vehicle: 2012 Ram 1500 4X4
Rep:68
Cat Daddy will become famous soon enough
i have the same light bar...big fan of custom dynamic light run tthem in my HD i just trimmed the lip off the top of the trim ring for the jack...the lights are some of the brightest out there you will not be unhappy with it I bought a 4 way plug and wired it to my tail lights direct so left my plug open in the rear.. Take the tail gate off for sure makes install much easier just be sure it is low enough to clear bottom swing of the tailgate when you open it...piece of cake you will love it ...if you buy direct they have a great warrantee
20X9 Black XD Hoss with painted caps 275x65x20 NittosTerras,Bilsteins 5100's @ 2.1, .75" in rear,laminx tinted head lights,tinted tail lights & 3rd brake light, S&B,Fastman 84 TB,18' Magnaflow,T1000-hemifever,cabin filter,RECON led cab lights,custom dynamic 60" light bar,tow hooks,debadged ,6" shorty ,painted grill and front and rear emblem , AMP power step ,F1 Bacflip bed cover ,Mopar bed rug kit
Old 08-13-2013, 12:34 AM
Cat Daddy's Avatar
Rep:68
With the tailgate off it is easy to use a little mashing tape to get your straight line ...like I said they are great company to deal with...falls apart they will fix it...have run their lights a long time and never had issue..lol..had a guy stop me tonight and ask where I got the light bar....SUPER BRIGHT !!
Old 08-13-2013, 12:39 AM
Cat Daddy's Avatar
Rep:68
Oh yea 1 thing I had to do was put 2 or 3 layers of emblem tape right at the ends ...there is a 1/8 lip maybe where the body wraps around ,if you look in you'll see what I mean ,mine has been there for over a year and never moved
Old 08-13-2013, 12:43 AM
Cat Daddy's Avatar
Rep:68
Did not read your whole post...you already know CD..
Old 08-13-2013, 08:39 AM
Rep:16
Thanks Cat Daddy for all of the insight. Still might try the magnets. I might order the ones I posted the link to and start with maybe 5 of them. The light comes with a 3M promoter pack to aid the 3M tape to adhering. I will use that on the back of the magnets and just remove the portion of the 3M backing where I will place the magnets. Then maybe let them sit overnight before trying it. I guess the worse thing that could happen is I have to remove all of the 3M tape from the back of the light and get more and just start over.
Old 08-13-2013, 11:44 AM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
ive never dealt with a light bar, im looking into it as well. but magnets?! ive never heard of that idea! you probably just came up with the coolest way to do it..
Air horn "AHHOOOGA" horn,
Green Interior LEDs
Old 08-13-2013, 01:15 PM
Rep:16
I ordered the magnets as well and when it all comes in I will try the magnet install and take pictures and share on here.
Old 08-16-2013, 10:08 PM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
I have the same bar as well. Never had a problem with it in the way of removing the spare and I remove the spare often enough to have the truck oiled. I took out that plastic piece in the access hole. The only problem I've had is wiring problems but thats more my soldering skills and winter weather than anything. Next time I'd just get the plug and play one instead.
Old 08-17-2013, 12:15 AM
Rep:16
Got the light bar, wiring adapter and the magnets in. I installed the wiring adapter and the magnets on the back of the light bar. I will let the magnet sit overnight before trying to install tomorrow so they will have a little time to set to the 3M tape.
I hope this wroks, I will share more tomorrow.
