Old 08-09-2013, 09:02 AM
Jmac86201's Avatar
Jmac86201 Jmac86201 is offline
Trim Level: Grey
Color: Grey
Rep:15
Jmac86201 is on a distinguished road
Default Front End Squeaks
I just recently noticed that my front end is squeaking. I have no idea what it could be. I have the 6 inch RCX lift with a 1.25 inch body lift. Bilstein struts as well. could it be my struts, or the body lift. Any insight on this would help alot.
Old 08-09-2013, 11:56 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
spray some lube on control are bushings, see if that hepls, and any moving parts
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 08-10-2013, 12:32 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Definitely start with spraying some lube on all the bushings throughout the kit. Get someone to jounce the vehicle while you are underneath it to try and pinpoint the squeak as well. That's what helped me eventually find mine.
It might be your body lift though. And if it is there's no way to fix it that I know of. I know of a few members who have removed their body lift for that very reason.
Old 08-25-2013, 10:20 AM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
I had the squeak and it turned out strut nut was not tight at all. Shop had to re do the job and tighten correctly. I had 1/2 gap between nut and strut plate took a pic with my phone to actually see in there
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
