Old 08-08-2013, 12:03 AM
BKilburn BKilburn is offline
Trim Level: Big Horn Crew Cab
Color: Maximum Steel
BKilburn is on a distinguished road
Default Help!! Electronic Throttle Control Problem
A few months ago my truck lost about 50% power and a red lightningbolt flashing with the following message: "SERVICE ELECTRONIC THROTTLE CONTROL" on the screen. When I stopped and turned the engine off and restarted it the message was gon but the CEL was on and the lightning bolt was still flashing. By the time I got to the dealer it reset itself. They did a software update and said that should fix it. A few days later after fueling up it happened again. This time the dealer replaced the gas tank. A few days later it happened again! This time the dealer replaced the gas cap?? Low and behold a few days later it happened again. This time they replaced the gas pedal. Guess what, once again it's happened!! Can anyone help? Has this happened to anyone else? Any help is greatly appreciated. Thanks
Old 08-08-2013, 06:43 AM
Monster5601 Monster5601 is offline
Vehicle: 2013 RAM 1500 Laramie
Color: Cherry Red
Rep:465
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Strange that there are not trouble codes set indicating additional issues. Typically these codes would be static and not disappear. Ask you dealer to install a monitor in your truck to capture the event.
You may also want to brush up on Florida's Lemon Law because you may already qualify, "repair of the same recurring problem at least three times":
http://www.myfloridalegal.com/lemonlaw
Old 08-08-2013, 10:23 AM
KJ48 KJ48 is offline
Vehicle: 2013 1500 Ram CC
Color: Mineral Gray
Rep:117
KJ48 will become famous soon enoughKJ48 will become famous soon enough
My advise is find a different dealer, those codes shouldn't just disappear if the CEL goes out - especially anything that lights up the red ETC light.
They had to have some data to start replacing parts, why replace a fuel tank on a guess?
About the only thing left to replace is the throttle body and its sensors, its called the shotgun diagnostic approach, keep throwing parts at it until its fixed...
Old 08-09-2013, 01:34 AM
Thanks for the replies. Greatly appreciated :-)
Old 12-01-2013, 04:17 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
Did you get your problem fixed.
Sadly one day into getting my 2014 Ram Laramie, with only a few dozen miles on the odometer, this warning light has appeared on my truck. It's Sunday, but am going to take it in in the morning. Would be helpful if I can have an idea of what the problem may be.
Thanks
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
Old 12-01-2013, 09:39 PM
Power Wagon's Avatar
Power Wagon Power Wagon is offline
Vehicle: 2013 Ram
Trim Level: Quad Cab 4x4
Color: Deep Cherry Red Crystal
Rep:45
Power Wagon is on a distinguished road
Just noticed this thread and am curious about the outcome.
BTW, did the dealer name start with a "P" and end with an "M" ?
Old 12-01-2013, 11:10 PM
After 5 trips to the dealer and a formal letter to Chrysler Corp, Chrysler sent a team of technicians and kept my truck for a week. They ended up replacing the entire engine wiring harness. It has been a couple months and the issue has not returned. No the dealer didn't start with a P. It is the local Fort Myers dealership.
Old 12-02-2013, 07:05 PM
Rep:69
Wow
Well, my 2 day old 2014 Laramie with just 98 miles on the odometer, got dropped off at the dealer today.
Again, the alert first popped up with 14 miles on the odometer even before I signed the delivery paperwork. They stated it was in shipping mode.
I'm hopeful to get a response tomorrow as to what the issue is.
btw, how do they replace the entire engine wiring harness?
Do they have to pull your dash completely apart?
If so, do you have new squeaks and rattles now? As in my experience whenever panels come off for repair, they never seem to be put back on as well and usually begin to squeak and rattle.
Or do they replace all the wiring under the hood? If so, did you inspect to see if you have any paint scratches from the wiring harnesses hitting your car or from careless technicians leaning over your truck without putting protective covers over the 1/4 panels?
thanks
Old 12-10-2013, 08:22 PM
eethomas's Avatar
eethomas eethomas is offline
Vehicle: 2012 Ram Laramie Longhorn
Trim Level: Longhorn
Color: Black & Gold
Rep:15
eethomas is on a distinguished road
I had the check engine light & the flashing lightning bolt 2 weeks ago. The dealer first replaced the gas pedal and that did not fix it. Then they replaced the PCM and that seems to have fixed it. Have had it back for 6 days now and so far it is running good. Hopefully that took care of the problem. My truck is a 2012 Longhorn with 13,000 miles on it. Don't know why many are having this problem with the Electronic Throttle Control.
Eric Thomas
2012 Laramie Longhorn
