Old 08-09-2013, 01:57 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Originally Posted by M3T View Post
Please see below this is what im trying to get too maybe a bit lower than this any perfered vendors for lift/wheels?
Beautiful truck! But that thing is huge. Trust me, pics don't do them justice! My truck doesn't look huge in pics, but in person, it's enormous! If that's the look you like, a 4 or 5 inch lift and 35's will be a good option.
Contact Bully Performance, he'll take care of you.
Old 08-12-2013, 01:09 PM
Trail Whale's Avatar
Trail Whale Trail Whale is offline
Vehicle: 2012 Ram 2500
Trim Level: Power Wagon ST
Color: Mineral Gray
Rep:87
Trail Whale will become famous soon enough
You can stay WAY lower than that and run 35s! A leveling kit, or even better a small lift will do it fine. I will be pulling the trigger on a 3" Carli lift today, it will fit 35s easily! (I'll be cutting the fenders some so that I can stuff 37s under it with full flex but, 35s will fit easily!)
The main thing your have to watch out for is the width of the tires and the backspacing of the wheels, those are the main criteria for putting big tires under a 4th gen. DON'T go by the stated tire width, research the tire and look at its actual width (prime example that I have come across: the popular Toyo Open Country mud terrains are listed as 37x12.50R17 BUT their actual width (on an 8" wide rim) is 14.6 inches!!!) get a fairly narrow 35 on a wheel with close to stock backspacing and you will be good to go!!! If you go with less backspacing than stock, the tires will stick out more and will give more control arm clearance but, they will be more likely to contact your fenders. Do not go with more backspacing than stock, as you will have a lot of issues including (but not limited to) a lot of increase in turning circle diameter since your tires will hit the control arms well before full steering lock. I would stay close to stock backspacing (I'd run a little less backspacing than stock to get more control arm clearance and to get a bit beefier stance) and maybe look into some control arms that give extra tire clearance. (their are MANY on the market to choose from!)
The truck in the pics above looks really cool but, to my eye, it needs 37s or even 40s to look perfect at that lift height! You don't need a big lift to fit 35s! Also, remember, the larger lift you go with, the more $$$ you'll be spending, not only on the lift but on other things that have to be modified for more lift:
extended brakelines
extended driveshafts
long arms (any lift over 4" and you'd be well advised to go long arm, tall short arm lifts compromise geometry and ride)
new rear springs (with a big diesel's torque, tall rear blocks are not gonna be a good thing!)
Old 08-27-2013, 12:16 AM
WydOpen's Avatar
WydOpen WydOpen is offline
Vehicle: 2010 Ford F350
Trim Level: Lariat
WydOpen is on a distinguished road
I've been looking at lifted Mega Rams lately and looking for a similar setup you're going for. Here's something along the lines of your preferences...
2013 Mega Cab 2500 with 6" RCX lift, 325/55-22 tires, and 22x12 wheels:
He's "megaram13" over on Cummins Forums.
- Rob
Old 08-27-2013, 12:19 AM
Man that lift Mega ^^^ has me drooling
