Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 08-06-2013, 04:41 PM
Gebhardt92 Gebhardt92 is offline
Vehicle: 1998 dodge cummins 2500
Color: green
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Gebhardt92 is on a distinguished road
Default 1998 dodge cummins 2500 24v - intermittent power loss, need diagnosis
hi I am in desperate need of a diagnosis for my truck issue.
I have a '98 dodge cummins 2500 3/4 ton 24 valve, 5 speed, of which has an intermittent hard start and also at random occasions while driving the engine will cut out for a split second resulting in check gages light to come on then, but goes away right after and continues driving normally. from an outsiders point of view they would think id let the clutch out too early on the edge of stalling, but that's not the case.
Previous Repairs:
The lift and injector pump both were replaced a bit over 2 years ago, I recently jus replaced the lift pump once again, the fuel filter, and the air filter;
I have an Edge Juice chip installed however that too has been fully disconnected and ruled out, as well as the command start (compustar).
Most people suggest it might be the injector pump but I've had the truck in to multiple mechanics and they have leaned away from that, but it also occurs so irregularly that any mechanic or dealer I've taken it to, hasn't been able to duplicate the symptoms.
If anyone has any suggestions or opinions please message me!
Old 08-16-2013, 10:24 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
crank sensor on code? Hadn't hung around here much, the diesel forums will get you some help. R...
1998, 24valve, 2500, cummins, dodge
