Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 08-03-2013, 04:39 PM
silver03ram silver03ram is offline
Vehicle: 2003 Dodge Ram
silver03ram is on a distinguished road
Exclamation stock 4.7 with nitrous
yes I have a 4.7 stock but want to install nitrous just to play around on the highway can I run nitrous on a bone stock 4.7 or what will I need to change on it and wat system would be best to install ?also I need it to be safe since its my daily driver I really appreciate it thanks
Old 08-03-2013, 05:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Talk to member darknight, I'll send him a link to the thread. He has the later 4.7L but he should be able to give you good info.
Sean
Old 08-03-2013, 05:44 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Hell yea it'll be easy for your engine, get a nozzle system I can get you a kit number here in a bit.... Then your gonna need a custom tune. You can get a custom tune from a local tuner or Sean from hemi fever. If you are just gonna be messin around I suggest a 100 shot. It'll be worth all the hassle. Then you will need to find a spark plug that is one stage colder, one heat range colder than stock. And you will be set for a 100 shot.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 08-03-2013, 05:46 PM
Color: Gloss Black
Rep:141
Tune should be set to 1 degree retard timing
Old 08-03-2013, 08:12 PM
I appreciate the help how much would all this put me at money wise after installation? and do yall know anything about racing gears? or should I not mess that?
Old 01-05-2014, 04:10 PM
SlowRed57's Avatar
SlowRed57 SlowRed57 is offline
Vehicle: 2004 Dodge Ram
SlowRed57 is on a distinguished road
my bud has been running a 100 shot for over 1 year with no problem, he runs superchips and only has a fuel pres reg. the dry shot raises the fp reg late and the computer adjusts accordingly. never gives him problems and it moves pretty good
4.7, nitrous, stock
