Old 08-01-2013, 08:02 AM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
Default Concern about rake on 6" rcx lift
So just got the kit installed.... And there's a really noticable rake. What can I do to fix this? I want her to be even. Maybe those adjustable blisteins?? Any help? I've been looking up the blistiens, is there a specific line to help level a 6" lift? I noticed there is different kinds. I know I need the 5100 series but which specifically? Also its noteworthy to say I have a .75 spacer on the rear
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 08-01-2013, 09:44 AM
doolin64 doolin64 is offline
Vehicle: 2013 RAM 1500
Trim Level: SLT - Bighorn
Color: Grey
doolin64 is on a distinguished road
Why not remove the spacer first?
Old 08-01-2013, 10:22 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
I don't think there are any threads about this already here.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 08-01-2013, 01:13 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I just replied to your post in my thread but I'll post it up here again for you.
As doolin64 said, the first thing I would do is remove the rear spacer.... With the lift you have and the tire size you're running I just don't see the point in having it in right now. Put keep it for later on down the road if you decide you need it.
But yes, the Bilsteins are the only way to achieve more front end lift and level out your truck. The part number is 24-187367 (Bilstein 5100 Front Adjustables 09-13). As you saw in my thread I set them at 1.4" (with no rear spacer) and it leveled out my truck perfectly.
Old 08-01-2013, 04:17 PM
Rep:160
Thanks again man. I realize theres other threads but I'm on my phone and busy at work so I appreciate it a lot.
My Mods
Old 08-01-2013, 05:33 PM
This is partially true....I say partially as you can go with a Revtek pre load spacer that acts like the Bilstiens.
However the Bilsteins are still my recommend choice
