Old 07-31-2013, 10:43 PM
BuckWild09's Avatar
BuckWild09 BuckWild09 is offline
Vehicle: 2007 Dodge Ram 1500 Hemi 4x4
Rep:63
BuckWild09 will become famous soon enough
Default Lift shackles or add-a-leaf
Right now my truck is raked maybe 1" with my bils set @2". im putting on my 6" rcx in a couple weeks but it is 6" front 4" rear. Id like to keep my rake or atleast level. Does anybody have experience with the tgc shackle or add a leaf??
I have a body lift so im kinda shying away from a shackle cause I dont want them to be showing but at the same time i dont want a super stiff ride.
And will this 2" mean i need a even bigger driveshaft spacer because of the change in geometry?
3" Zone Body Lift--6" RCX-- Bils @ .5"-- 20x12 Fuel Hostages--37x13.5" Toyo MT
Old 07-31-2013, 10:46 PM
gonefishin776's Avatar
Rep:1900
Even tho RCX claims the kit "levels" itself due to the 4" rear, 6" front. Most still come out with a rake and use bilsteins to level it. So you'll be good to go, keep your bilsteins where they are and you should be pretty close to level
Old 07-31-2013, 10:57 PM
BuckWild09's Avatar
Rep:63
Thanks Fish! I hope your right I just rather avoid readjusting them Bil's if I have to
Old 07-31-2013, 11:09 PM
Rep:1900
Theoretically you shouldn't have to. But definitely hold off on spending more money than you need to.
Old 08-01-2013, 09:23 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
+1!! best post of the day!!
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
